Scale 4x4 R/C Forums
Scale 4x4 R/C Forums (http://www.scale4x4rc.org/forums/index.php)
-   Help wanted! (http://www.scale4x4rc.org/forums/forumdisplay.php?f=116)
-   -   CMS For SCX10 (http://www.scale4x4rc.org/forums/showthread.php?t=66961)
Coolaid202 02-14-2012 06:53 PM
CMS For SCX10
Im looking for a kit that will replace the front plastic chassis peice that the bumper mounts in with a metal one that would let me mount the steering servo across the front of the chassis behind the cross peice. It does not need to still hold the bumper. Does anyone know of such a kit? Thanks.
stewbaru 02-14-2012 07:57 PM
Hand Bros CMS kit.
Doesn't mount quite how you describe, but is the most efficient and easiest to use, IMO.
stewbaru 02-14-2012 07:59 PM
Here y'go, done the hard work for you.
HyperMark 02-14-2012 09:37 PM
If you go for this, make sure you get right one.
There is one for the SCX10 and one for the SCX10 Honcho.
I have one on my Honcho and I love it.
stewbaru 02-14-2012 10:22 PM
Thanks Mark, I forgot there were two variants.
BADMUTHATrUCKER 02-15-2012 12:58 AM
The RC4WD kit gives you the metal cross members you asked for.
http://store.rc4wd.com/-Steering-ser...10_p_1419.html
stewbaru 02-15-2012 01:17 AM
Hadn't seen that one before...
Does it use A '5th link' to eliminate bump steer?
HyperMark 02-15-2012 01:25 AM
By the looks of that photo there is no panhard and its still using the factory 'Y' for the top link.
Also its not mounted across the front like the original poster requested.
Pretty much the same as the Hand Bros but not 3 link with panhard.
And on the opposite side.
Coolaid202 02-15-2012 06:37 AM
Thanks for the replys everyone but with what I'm building I really need it mounted across the front.
Willezcr8 02-15-2012 10:33 AM
This is what you're looking for...
http://www.scale4x4rc.org/forums/showthread.php?t=56106
Checkout the vendors section, GCM sells them.
Coolaid202 02-15-2012 02:08 PM
That's it. Just what I'm looking for, thanks.
winner 02-15-2012 02:09 PM
make one yourself like i did?
lol its really easy, i could probably make it for you too.
stewbaru 02-16-2012 12:13 AM
Bump steer?
winner 02-16-2012 06:03 AM
Originally Posted by stewbaru (Post 897632)
Bump steer?
with my 80mm shocks only like 1cm of bump steer, hardly noticeable. and im not going to build a pan hard bar for it either. yes it mite eliminate bump steer but it also stiffens the suspension and does not allow both shocks on each side to compress at the same time.
Coolaid202 02-16-2012 06:46 AM
I could but I have found that if I can buy a part that is made for what I'm trying to do it seems to work a lot better then if I make it. And for the $30 for the GCM kit how much it my time worth?
High steer knuckles might fix that....
