I watched Greg talk to Mr. wedico at Indy last year and when Gregs back was turned the same things seamed to have been said about him..Running it to hard did not put it together right BLAH BLAH BLAH case and point there stuff is junk! and they do not take care of there coustomers..Look at the greaman boards i see more other brands of loaders and haulers then I do Wedico..Watch the vids on You Tube of the shows in German and you see more other brands then Wedico??? Why is That??? Hmmmmm :sht: Dont tell no one..... |
It won't be a simple "add-on" modification, I am certain of that. ;) I'll do some figuring next winter. |
10-4 Paul :nice:
I've heard alot of 2nd hand information from others that wdc Germany thinks us north american owners of their models are substandard builders who are the sole cause of the problems we're having. Supposibly, when the 345 comes to market in a yr or so, it will be shipped to the USA as a pre-built model only... for an added cost no doubt. If that is indeed true, then 100% positively I'll never buy one! Yeah, I've noticed that too! It's rare that you'll ever see any wdc construction models of owners "from" Germany. But you'll always see some Stahl excavs or dozers or loaders though, and I doubt that it's for the sole reason that Stahl has been around longer. ;) |
Hi Joe
Did you sort out your radio glitches that you were having ????? it was the 740 wasn't it was it the polka radio or something else ?? Daniel |
Hello Daniel
No, never had enough time to sort it out before the 740 quit again. Both Polk radios continue to work fine with the other trks that are programmed into them. Even the radio that I thought glitched when the KH dump trk was climbing the wall. I live in an eighty yr old house, the wiring was done in the mid sixties, who knows what effect that may have on radio interenece at times? :thinking: |
Something new...
![]() ![]() ![]() ![]() My good friend Joe Ayrs from NY, USA built this scraper for me. Thanx buddy! :nice: The 1st one he built for himself to pull with his 1/16th 4wd tractors didn't look that big in tow, his tractors must be huge! I need to remove the ripper from the lead dozer & build a hitch; add another valve and then it will be good to go! :excited: Look for a video sometime this summer of this trio tearing up the garden! :lolbeat: |
Joe
That scraper is a MONSTER really great looking...Now time for some weathering the fun way working it hard!! :chug: |
Hey Joe the scraper looks good behind the dozer! I was starting to get worried when it wasn't showing up as fast as I thought it would have, I hope it works out for ya......
Yes indeed Paul! :whip:
No worries Joe, Customs (union workers) is always the holdup! I'm looking forward to the torture test this summer, we'll see if these two dozers are stout enough to crumple up this implement. :lolbeat: |
The scraper looks sweet Joe, many cudos to your buddy on the build. Is the JD dozer a new addition to the collection, or did I just miss it in the pics and videos somewhere? Anyway thats a great looking dozer, looks to have quite a bit of work done to give it the authentic JD look...
Also, how do you plan to run both the dozers at the same time? |
I got that JD dozer from Mitch last April, it's shown in the GT thread. It's a work of ART!
The rear dozer has the "ratchet" on the radio stick to set the throttle. I have a servo splitter electronic device which I'll install into the JD dozer to keep all the hyd controls working on the right stick. One side of the splitter operates the blade up/down & tilt - flip a switch on the radio to go to the other side of splitter to operate the scraper with the right stick again. It's a nifty device I picked up from Leimbach yrs ago to operate the tracks with the sticks on my excav with a regular 6ch radio. Then I discovered the Robbe F14 radios with the proportional sliders and now I can walk up a hill using all 6chs at once... though it's a little difficult to perform (wish I had foot pedals to plug into the radio). :lol: |
That is avery nice dozer, I'll have to go find it on GT and take a look.:drool:
Thats quite a handy device to run the scraper, and should work quite well considering you shouldn't need to run the blade and the scraper at the same time. :banghead: hopefully anyway... I bet that is a trick to run the sliders and the boom and crowd all at the same time. Could you do a little plastic surgery and put the sliders on the bottom or front of your tx so you could run them with free fingers? |
i see that you got a scrapper now joe i gess i will have to come and drive the poush dozer for you cus well i don't think you can drive both at once. looks grate behind the jd.
Yes you can Martin, I'll lyk when it's ready to roll. :cool:
I have the darnedest luck when it comes to electronics, especially these sensitive Leimbach speed controls... I blew the dirt off the dozer with pressurized air before bringing it upstairs for pictures with the scraper, even gave it a bit of blast under the cab and hood... all clean. A few days later I take it back to the basement and the model won't work properly. Push the stick forward and one track goes forward & the other goes backwards, I can't get it to work right. I take the cab floor off so I can get to the 3 adjusting pots, I can't correct the problem. :thinking: I changed it out today with a spare one I had on hand. There's no other reason I can think of for it going haywire... if there was any moisture in the pressurized air, it was days before turning it on again, so it shouldn't have short circuited. This esc was the original that came with the model in 02, so I guess I got my money's worth out of it anyway... but still. :'( |
| All times are GMT -6. The time now is 02:50 PM. |
