Go Back   Scale 4x4 R/C Forums > R/C Manufacturers/Venders/Retailers > RC4WD
Old 12-27-2009, 08:42 PM
sig p232's Avatar
sig p232 sig p232 is offline
I'm having Scale4x4R/C's baby!
Member Number: 11
Default R2 2-speed tranny with DIG
What is the spring included in the package for? Also, is there a reason why the motor will not fit without removing a single screw in the transmission.
Nate
Check it out, everyones doing it.....
www.5280rcpullingclub.com
Old 12-28-2009, 12:21 AM
Racer4Life's Avatar
Racer4Life Racer4Life is offline
Just chilling and working on some scale stuff
Member Number: 1512
Nate
The spring is for the dig side. If you have a high strength servo, you should not need it. It was added for servos that are not that strong to help disconnect the dig function.
As for the motor fitting. Your going to need to be a little more descriptive. I can't really help to much with that unless you post a photo or provide a little more info.
Hot Deals. Check it Out!
Old 12-28-2009, 12:36 AM
sig p232's Avatar
Member Number: 11
Without removing the missing screw from the transmission, the motor and pinion will not fit.
Nate
Old 12-28-2009, 02:24 AM
LOSIASSOCIATED's Avatar
LOSIASSOCIATED LOSIASSOCIATED is offline
HD Tow King!!
Member Number: 4426
B/S/T Feedback: (5)
What tooth pinoin you use mine dont do that,mine is real close to the curved part of the trans.
Old 12-28-2009, 10:32 AM
sig p232's Avatar
Member Number: 11
The pinion is the one they sent.
Nate
Old 12-28-2009, 12:43 PM
Racer4Life's Avatar
Member Number: 1512
With the stock 8t pinion I don't have that issue with mine.
I can see with some motors depending on how the front bell is designed that it would hit.
