Go Back   Scale 4x4 R/C Forums > R/C Manufacturers/Venders/Retailers > GCM-Generis Custom Metalworks
Old 08-25-2011, 09:13 AM
UK_Andy's Avatar
UK_Andy UK_Andy is online now
Give Ian a free pen!!
Member Number: 4544
Originally Posted by sloppy View Post
wouldnt it counter rotate if setup like this
Yea, it would. If you try it youll have to turn your back axle upside though
Willows CTP for all your printing plate needs
Old 08-25-2011, 07:16 PM
sloppy's Avatar
sloppy sloppy is offline
kame hame haaaaaaaaaaaaaaaaaaa
Member Number: 863
Right but on any counter rotation setup you have to flip a axle.. except the wraith axles on those the diff can just be flipped in the axle itself..
http://nostr.net/forums/
Old 08-30-2011, 12:31 PM
YJ_Driver's Avatar
YJ_Driver YJ_Driver is offline
R/Cing since 1985
Member Number: 9354
Originally Posted by pardonmyn00b View Post
Fact, you can reverse your throttle on the transmitter.
This is fine with the typical crawler setup: FWD/Drag brake/REV to change it to REV/Drag brake/FWD as the ESC won't care. But if you use any other setup such as a bashing FWD/neutral/brake to reverse then pulling on the trigger will give you brakes and when moving forward fast you won't have any brakes.
Another thing to consider is whether the ESC has the a sufficient current rating in reverse which will now be your forward.
The best thing is to do it at the ESC, either through programming or switching wires.
Old 01-22-2012, 09:30 PM
Tremelle's Avatar
Tremelle Tremelle is offline
Member Number: 2144
Will this transfer work with the wraith transmisions?
Old 01-23-2012, 04:10 AM
generis's Avatar
generis generis is offline
RC Parts made in Canada
Member Number: 1923
You can use any transmission to drive the transfer case. If you want to use this in a wraith, you would have to mount the transmission some other place.
This doesn't bolt on to the transmission, it sits separately away from the transmission, so you can use wraith, or scx or losi, or Wk or just about anything to drive the tcase.
GCM Crawler Builds and parts Links Here
Youtube Channel: GCMRacing1
Old 01-25-2012, 08:27 AM
Tremelle's Avatar
Member Number: 2144
Thanks for the reply. I just submitted an order for one of your transfer cases.
Old 03-14-2012, 10:27 AM
BigSki BigSki is offline
Member Number: 5394
Is there enough room inside of the housing to use different tooth count gears to get an under drive or over drive effect?
Old 03-14-2012, 10:28 AM
generis's Avatar
Member Number: 1923
No. This was designed to have the bare minimum clearances everywhere and be 1:1, and tiny and strong.
Thanks
Old 05-05-2012, 10:37 AM
Member Number: 5394
Do you sell any individual parts for the t-case? I'd like to buy 3 of the shafts if possible.
Old 05-06-2012, 01:53 PM
generis's Avatar
Member Number: 1923
Sure thing, I'll send you a note on PM.
Thanks
Chris
GCM
Old 05-16-2012, 09:32 AM
Donzi63's Avatar
Donzi63 Donzi63 is offline
Member Number: 6435
Hey Chris. Just went to the web site and the complete kits are out of stock. More anytime soon? Thanks, Frank.
IF YOU CANT COMMAND THEN YOU MUST OBEY.
Old 05-16-2012, 09:37 AM
generis's Avatar
Member Number: 1923
Back in stock! We try to keep ahead, but sometimes there's a bit of a delay, sorry!
Old 05-16-2012, 09:42 AM
Donzi63's Avatar
Member Number: 6435
Thanks!!
Old 05-16-2012, 09:56 AM
Donzi63's Avatar
Member Number: 6435
Order placed, Thanks.
Old 05-16-2012, 10:07 AM
UK_Andy's Avatar
Member Number: 4544
Whens the leaf chassis kit gonna be back in stock?
