Go Back   Scale 4x4 R/C Forums > Scale On-road R/C > Car Discussion
Car Discussion Touring cars, Rally Cars, Drifters, whatever!
Talk among yourselves!
Old 03-12-2012, 07:29 PM
xmod4life's Avatar
xmod4life xmod4life is offline
Member Number: 2621
B/S/T Feedback: (3)
Default - Tamiya TA-05 Ver.II 240Z -
Started this build exactly a month ago...
Originally Posted by Dr. Kustom View Post
Few years back, I had a Tamiya TA-04 Pro as a gift, knew nothing about it, and I wasn't into 1/10 at that time, so I sold it on eBay for dirty cheap, regret selling it. Recently I got into the 1/10 scene, starting off with an Axial SCX10, and this Tamiya TA-05 Ver.II will be my second 1/10 build.
I'm still in the process of building this kit, and will update this thread when I get more work done.
Bag A:
Part 1 - Motor mount.
This step will require to use parts from the K parts tree.
Part 2 - Attaching motor mount and suspension arm mounts.
This step will require to use parts from the M parts tree.
Part 3 - Ball differentials.
This step will require to use parts from the S parts tree.
Part 4 - Rear gearbox.
This step will require to use parts from the A parts tree.
Part 5 - Front gearbox.
This step will require to use parts from both A and N parts tree.
Part 6 - Attaching gearboxes.
Bag B:
Part 7 - Rear axles.
This step will require to use parts from the E parts tree.
Part 8 - Rear arms.
This step will require to use parts from the A/D/M parts tree.
Part 9 - Attaching rear axles.
Part 10 - Transponder stay.
Part 11 - Attaching rear damper stay.
Part 12 - Front arms.
Part 13 - Attaching front arms.
This step will require to use parts from the A and M parts tree.
Part 14 - Front axles.
This step will require to use parts from the C and F parts tree.
Part 15 - Attaching front axles.
Part 16 - Attaching steering linkage.
Part 17 - Front damper stay.
This step will require to use parts from the K and N parts tree.
Part 18 - Push rod.
To be continued...
Very busy, indeed. It does comes with a Gallardo body, but I don't plan on using it anyway.
Update: Bag C.
Part 19 - Damper assembly 1.
This step will require to use parts from the V and Q parts tree.
Part 20 - Damper oil.
Part 21 - Damper assembly 2.
Part 22 - Attaching dampers.
Part 23-26 skipped.
Part 27 - Wheel assembly.
Part 28-31: Attaching wheels, urethane bumper, battery holder and snap pins.
Part 28 require to use parts from the A parts tree.
4x4 stance...
To be continued...
ExtremeRCCrawlers
Old 03-12-2012, 07:30 PM
xmod4life's Avatar
Member Number: 2621
B/S/T Feedback: (3)
Update: The new body is here! Tamiya Datsun 240z.
The TA-05 front end aren't design to run any negative camber, so I trimmed up the H carriers to clear the lower suspension arms. Also shorten all the upper suspension linkages.
Update: Got my electronics in few days ago.
Castle Creations Mamba Max Pro with 7700KV motor.
The ESC was a bit too big for the chassis, so I had to mount it up side way and taped the switch right above the ESC for easy access.
Receiver is an Airtronics FHSS-2 3 channel.
Servo is a Traxxas 2075 with new servo gears.
It's power by the same Gens Ace 3S Li-Po that I used on my SCX10.
Here a quick video of it in action.
http://www.youtube.com/watch?v=GUuPWwLGurE
Update: Body masked.
Then a coat of silver.
Update: Most of the paint work is done for now.
ExtremeRCCrawlers
Old 03-14-2012, 05:22 PM
xmod4life's Avatar
Member Number: 2621
B/S/T Feedback: (3)
Update: Picked up a set of SSR Formula Mesh rims from Japan. Got the wheel wells trimmed up, ready for some wide fender flares.
ExtremeRCCrawlers
Old 03-14-2012, 06:31 PM
Cassius's Avatar
Cassius Cassius is offline
Is that my driveshaft?
Member Number: 5131
I'm sorry if I sound ignorant but why are the tires grinded like that?
Old 03-14-2012, 06:51 PM
xmod4life's Avatar
Member Number: 2621
B/S/T Feedback: (3)
The sidewall looks like that when I got them, they are the Sushi drift tires, very cheap, so don't expect them to be high quality anyway. However, I did sand down the sidewall some more. 1.) To get more of a stretched tire look. 2.) Try to smooth out the uneven spots. But they still looks the same. I guess it's just the material of the tires.
ExtremeRCCrawlers
Old 03-14-2012, 08:57 PM
Terminator13's Avatar
Terminator13 Terminator13 is offline
All mighty and strong termite. xD
Member Number: 1435
Sidewalls are like that (atleast at this scale, unless your are going for that look) to keep the car from catching the pavment during a sideways drift.
Pretty cool looking kit. I've been dying to build another onroad car. Probably want to get a rally car or something. Hahah.
Old 03-15-2012, 06:54 PM
Looks cool, I allways liked the look of the 240Z. I am working on a rally 240Z now.
Old 03-17-2012, 04:01 PM
xmod4life's Avatar
Member Number: 2621
B/S/T Feedback: (3)
One of the reason I sand down the tires on an angle like that is to prevent it caught on something while drifting. Most importantly, I can get the wheels closer to the wheel well.
Rally car should be fun, looking forward to get one too.
Thanks walter, be sure to post up the progress of your's.
Update: Got the fender flares installed.
Wheels fitment.
ExtremeRCCrawlers
Old 03-26-2012, 03:56 PM
xmod4life's Avatar
Member Number: 2621
B/S/T Feedback: (3)
Lights.
ExtremeRCCrawlers
Old 03-30-2012, 07:56 PM
Bird8oy's Avatar
Bird8oy Bird8oy is offline
I have a problem and they don't know what to call it...
Member Number: 9312
B/S/T Feedback: (25)
This thing looks nasty man ! ! ! Good work !
Old 03-31-2012, 04:15 PM
xmod4life's Avatar
Member Number: 2621
B/S/T Feedback: (3)
Thanks!
Update: Pick up some new wheels.
ExtremeRCCrawlers
Old 04-27-2012, 11:05 AM
xmod4life's Avatar
Member Number: 2621
B/S/T Feedback: (3)
Took the Z out on a rainy/foggy night for some photo shots...
ExtremeRCCrawlers
Old 04-28-2012, 11:25 AM
saiyan46's Avatar
saiyan46 saiyan46 is offline
Cat$h!tOne
Member Number: 7257
B/S/T Feedback: (57)
Nice Z, i like the Camero too, but it needs some LEDs.
scx10JK, scx10, slash, sc10, TT01EvoX, CycloneEvoX*A.S.T.R.*
