Go Back   Scale 4x4 R/C Forums > Monsters, Scale 4X2, & Non scale R/C > Monsters of R/C
Monsters of R/C If its massive, ain't scale, and can break an ankle when it hits you, put it here!
Old 03-21-2012, 12:14 AM
Default Hairba11's jugg, embiggenated. Bigfoot 5-ish
so project ADD kicked in, and i started working on something else.
picked up a jugg with upgraded axles and trans and started playing with it.
I got as far as reversing the link mounts on the front axle and chassis to put the trackbar 4 link on the inside to give me a little more clearance for some slightly larger tires.
i've had these kongs since my savage almost 8 years ago. I always have a plan for them but never use them because, well, they're too stinkin' big.
I've had this idea for a bigfoot style build for a while and finally have the chassis to do it.
the Jugg body will be removed in favor of a longbed king BF to stick with the early 90's feel. Bigfoot 5-ish.
and to keep this from being completely worthless, i managed to take one progress pic before calling it a night.
looks like i'll have about 1/2" between the edges of the tires at full steering lock.
Old 03-21-2012, 10:19 AM
got the rear axle knocked out this morning
full right steer
full left steer. there is about 3/4" of space between them while turning.
Old 03-21-2012, 02:18 PM
kurtcrittenden's Avatar
kurtcrittenden kurtcrittenden is offline
Member Number: 14737
Holy monster!!!!!
Old 03-21-2012, 06:11 PM
RustyBeater RustyBeater is offline
Member Number: 15872
amazing!
Old 03-21-2012, 10:28 PM
still need a little work on the body mounting, and i want to add a servo for the front axle for independent 4ws. i have some 1/4 scale 300 oz-in servos i'll be making mounts for.
Old 03-30-2012, 01:08 AM
quick update, although it shows a couple hours work and an hour of head scratching.
pulled the stock battery tray and made room for my 1/4 scale servo mount in the rear of the chassis for the front axle.
replaced the no-name plastic geared servo with a broken ear with a 200 oz-in MG995 china special for the rear steer.
came up with a servo mount and got the 300 oz-in 1/4 scale servo mounted up, then fired up the lathe an made a custom 7.5" steel drag link which allowed reuse of the Jugg rod ends for the front steer.
next will be some maxx shaft drive lines and some electronics, then time for body fitment and finishing.
Old 03-31-2012, 08:09 PM
RCJEEPBUILDER's Avatar
I love my wife!!!!
Member Number: 1672
Looks awesome man! Cant wait to see you running it,Im sure you will put on a good show!
5 ton of fun
Old 04-03-2012, 09:39 AM
i think i need to make a sedan mold to form baking pans over for aluminum crush cars.
and in 60-90 days, i should be able to move out my house mate and rent this place, set up a real space for working on rc in the house, move in my fiance so i quit having to spend entire weekends over at her place and should actually be able to get some projects done instead of sneaking in a couple of hours a week.
the 5-ton will get done!
Old 04-09-2012, 10:06 PM
slight update.
rewired the motors in series from parallel, switched to a mamba max esc robbed from another truck and running on 3s lipo.
makes the 20t motors run on 1.5s
should have decent power without too much overheating while not actually being strong enough to break the axles with these huge tires.
my usual flawless neat wiring job
and a short video showing the independent front and rear steer. rear steer is just on a 3 position setup to make it easier to center. also showing plenty of pep even with 5.6 volts going to each motor. only one driveshaft installed right now, after all it is just a minor update.
Old 04-09-2012, 10:43 PM
gabehunt gabehunt is offline
SCX 10 Newbie Scaler
Member Number: 13084
looks like it makes some good power!
Old 04-13-2012, 09:06 AM
Richi Puppy's Avatar
Richi Puppy Richi Puppy is offline
Member Number: 1107
Man, that is going to look great popping wheelies and running over some cars.
Old 04-13-2012, 09:16 AM
UK_Andy's Avatar
UK_Andy UK_Andy is offline
www.mishacalvin.com
Member Number: 4544
Its great, I just think with the body on the wb could do with being a tad longer
Willows CTP for all your printing plate needs
www.mishacalvin.com
Old 04-13-2012, 08:54 PM
actually the body's wheel arches are about 8mm too short. not real noticeable. i got the rear centered and the front comes in about 5/16" closer to the bumper. i figure in nose overs it will help keep the grill from getting hit.
Old 04-13-2012, 09:57 PM
also looking at paint. got started tonight with a duplicolor ford silver metalic.
in 48 hours i can mask off and go for a dark blue metalic top coat, thinking of leaving the rockers and lower doors silver like this
but the blue is going to be closer to this truck
and here it is with color coat 1
Old 04-14-2012, 10:14 AM
Kruiser's Avatar
Kruiser Kruiser is offline
Member Number: 17724
Very Nice, I am wanting to do a bigfoot 12 finding the parma decals isnt easy though.
