Here's the showcase of the GCM offerings for the Axial EXO Buggy. >>> EXO parts link <<<
First up is the Diff upgrade. May seem like a simple thing, but this can make the difference between high maintenance and almost no maintenance. And saves a lot of dismantling the thing when the soft plastic diff case gives out. Works perfect for front, rear or center diffs in the EXO. |
Second, Here's the center diff motor mount option. >>> Parts links here <<<
This solid machined billet one-piece mount will cure broken motor mounts forever. It's got room for up to 40mm motor diameters, drops the motor position 2mm from stock, and allows 3 bolt mounting instead of 2 (with some gearing setups) using a 3rd screw slot on the centerline. |
#3
Here's the for the Diffs.
