Tools of the Trade If you a question about what tools we use in creating our trucks here. Also discuss any tool experiences you have, the good the bad and the ugly! Hand tools to all out CNC machines!
Old 11-06-2011, 12:10 PM
docsrcrepair docsrcrepair is offline
I dont procrastinate I just work better under pressure!!
Member Number: 1284
B/S/T Feedback: (9)
I've been thinking of doing this to my mill..only problem I would have to key the head onto the upright column. But beings I am a machine repairman I think I could come up with something.. Keep up the good work.
I take it that your just running off a encoder and not a scale?
I will use way too many smilies in my posts.. deal with it..
Old 11-07-2011, 11:30 PM
outcastrc's Avatar
outcastrc outcastrc is offline
The outcast: "modern day anti-hero"
Member Number: 200
Not even sure what a scale is.
Old 11-08-2011, 02:04 AM
IKke's Avatar
IKke IKke is offline
Oh hai!
Member Number: 5041
Stepper motors are usually driven without a encoder or scale. This is because stepper motors can be positioned(turned) quite precisely.
IKkeTech Waffle boards, steering Guards, scale wheel hubs, and more!
Check IKkeTech on facebook
Old 03-31-2012, 03:16 PM
outcastrc's Avatar
Member Number: 200
Wow, 4 months have already gone by and I haven't been able to touch the mill. (father'n'law had a bad case of cancer and recently passed) I'll be starting back up on this project soon and if everything goes according to plan will also be starting up a new build thread. This time a Prusa Mendel 3d Printer. It will compliment the mill and the cad'ing I learn will aply to both. Will be interesting to see just what RC objects I can make with that.
Old 04-02-2012, 08:38 PM
BiLLy bOb's Avatar
BiLLy bOb BiLLy bOb is offline
Member Number: 528
B/S/T Feedback: (10)
im sorry to hear about your loss. I just went through the exact same thing with my father.
Old 04-18-2012, 07:12 PM
RCP57's Avatar
RCP57 RCP57 is offline
Member Number: 15398
I'm trying to decide between a mill like yours and top tech BF30. The top tech has a DRO installed and is almost twice the price. I would like to convert either machine to cnc later on but for the price difference I could almost cnc the king mill now. Have you done much machining with your mill? Do you wish it was a little bigger? The BF30 has its benefits but it might be a waist of money for building RC parts and the very odd steel piece. Do you know what the conversion cost over and above the mill?
Sorry to hear about your father inlaw.
Thanks Reg
Old 04-18-2012, 08:21 PM
outcastrc's Avatar
Member Number: 200
Thanks Reg
Good questions.... The mill seems more then strong enough for any aluminium you'd care to throw at it. One of the things I am finding frustrating right now is the mill can only do about 2600 rpm. which you need to compensate for by going slower then you could at a higher rpm. The mill is capable of moving so much faster then I can currently push it. You can bump up the speed on it at a cost of torque but then you have to replace the bearings. I think we are going to try to at least get it to hit 5000 rpm. 10000 would be nice but then I think it would need a new motor and controller to do that.
There's more then enough room on the X and Z, Y could be a little bigger but I don't plan on making anything so large that it should be a problem.
Realistically I think there is about 1500 into the basic conversion itself on top of the mill cost.
I made these this weekend to swap my stock rc lawnmower wheels for turf and field tires. Still have to do a little more work before they can bolt to the mower.
Old 04-18-2012, 11:55 PM
Madda's Avatar
Madda Madda is offline
Tracked vehicles fan
Member Number: 15583
Is direct drive better or belt drive?
Old 04-19-2012, 12:26 AM
outcastrc's Avatar
Member Number: 200
I can say that direct drive is simple and with large enough steppers they easily power the mill. So personally I don't see a reason to make it more complicated with a belt drive unless you go with a smaller system. The one area that I could see it is to put the Y stepper in the rear tucked away to keep the mill against a wall. The direct drive stepper system is quite deep and a belt system can change that to a much shallower depth.
Old 04-19-2012, 06:33 AM
Madda's Avatar
Okay, direct drive seems good enough for me.
What do you think, are the nema 23 570oz/in motors minimum to use or 425oz should be fine too? Of course the Z would get the nema 34.
Was it hard to get all the electronics working? I'm afraid of all that electronics in CNC...
What is the accuracy you are getting when cutting aluminium? Have you tried milling stainless steel and steel?
Old 04-19-2012, 10:05 AM
outcastrc's Avatar
Member Number: 200
The 570's don't cost much more then the 425's so it only makes sense to get them. I don't think the Z actually needs a nema 34 for the power personally but the size of the motor fits the mounting design so well so I wouldn't bother with a nema 23 on the Z.
If you haven't already check out Keling. They seemed the best bang for the buck when we ordered.
http://www.kelinginc.com/
