Old 04-14-2012, 12:24 AM
tozRovr's Avatar
tozRovr tozRovr is offline
Member Number: 14277
Default Land Rover 110 Pickup
Been a fun 3 weeks
Started with this...
Then to this...
Then here
OOOH! How about a Safety Devices Headache bar? YEAH!
Then...maybe a bit more...
Door handles and some rust next up is to finish my 1/4 depth pelican case to cover the body posts out back and to build the spare mount for the hood. There will be no spare, much less on the hood ( its a flippin horrible place to mount a tire, even with the correct bonnett and a tiny tire it kills visibility) I just want the apparatus there to hide the body pins
Well, now Logan needs some more protection...
Starts are:
SCX10
HH 27T Torquemaster Pro
CVD front axles, updated tranny outputs and diff inputs for pins.
Bunch of other random fun stuff.
Old 04-15-2012, 12:41 AM
Bulldog's Avatar
Bulldog Bulldog is offline
POWERHOUSE OFFROAD
Member Number: 10058
Not bad for lexan! Great weathering and scale bits.
Click here for some killer scale Video footage!
http://www.youtube.com/watch?v=IeT3rjS1wpI
Old 04-15-2012, 12:53 PM
tozRovr's Avatar
It's 2mm abs...a bit tougher than lexan but a bit harder to cut.
Old 04-15-2012, 12:57 PM
tozRovr's Avatar
Out on Mt Aggie today
Old 04-17-2012, 11:54 AM
tozRovr's Avatar
http://www.youtube.com/watch?v=CrMBB...ature=youtu.be
Quick edit from last week (can still see the body posts here)
Old 04-17-2012, 12:37 PM
jmarsh1976's Avatar
jmarsh1976 jmarsh1976 is offline
Member Number: 6726
Great action shots! Fun looking truck
Old 04-17-2012, 12:51 PM
Hondatouring Hondatouring is offline
Member Number: 13291
looks Good
Old 04-17-2012, 07:19 PM
tozRovr's Avatar
Thanks guys, Here you can see the new body mount setup and the 1:1 defenders mount for the spare...
Old 04-21-2012, 09:03 PM
tozRovr's Avatar
Revamped the front with a Reign RC Defender Grille for a Dingo...perfect fit. Just sanded down the stock grille a bit.
The Snorkel head started as two .036" strips of hastelloy scrap I had. I cut one strip and shaped it into a "C" and that is the walls...the top and bottom are pieces I trimmed, then tig welded to the "C." First I tacked them on then shaped the top and bottom a bit better, then seam welded the whole deal. I drilled the bottom out to fit the 5/16" main snorkel pipe. The grate in the snorkel head is the inner section of an Axial light cover trimmed to fit and glued in with some metal bonding CA we have at work.
Snorkel is held in with RTV and I'm working on a small bracket to run from the cage to the pipe.
Old 04-25-2012, 10:04 AM
tozRovr's Avatar
:biggthumpup:
Filing this one as DONE. I'm sure I'll add some small stuff over time, but as of now I'm stoked to be wheeling it
And the guts of it all...
Holmes Hobbies 27 Turn Torquemaster handwound Pro
Axial CVDs
Pinned outputs on the tranny and inputs on the diffs
RC4wd Steelies with Swamper TSL Boggers
RC4wd Winch
I built the full cage with 3/16" brakeline
Hand Built Snorkel
Boatsides fabbed from .030 Hastelloy
Reign RC Grille
