Go Back   Scale 4x4 R/C Forums > Other R/C and Misc > Static Models
Static Models This for you static display modelers. 1/24, 1/25, 1/18, 1/43, etc static display models, kits, pre-builts, whatever. If you got it, here's your forum.
Old 04-10-2012, 07:51 PM
oldskoolmini's Avatar
oldskoolmini oldskoolmini is offline
somebody call ghostbusters!!!!!
Member Number: 12168
Default scratch built dirt super late model.
This is a dirt super late model ive been building for a customer. it is 1/24 scale. about 90% will be scratch built with styrene.
here is the real car.
beginning of chassis fab.
rear 4 link mounts
more bars added and cockpit started
front suspension mounts
front bumper/nose mounts added
body mounts added
resin nose piece mocked up. might change tires. little too wide
Originally Posted by Ragnarok View Post
And this sphincter-brained hammer-ape is still employed? Where's my rifle?!?
IM THE UNIBALL LOONEY IN A WHEELCHAIR WITH A GHOST PROBLEM
Old 04-11-2012, 09:56 AM
sickness's Avatar
sickness sickness is offline
Member Number: 6516
I saw this, did a double take, looks like its gonna be killer.
Old 04-11-2012, 12:58 PM
thanks sickness!
Old 04-11-2012, 06:18 PM
CM_113's Avatar
CM_113 CM_113 is offline
the talkative lurker
Member Number: 3405
that is awesome!!! WOW!!!! glad to have your sticker on my truck
http://www.scale4x4rc.org/forums/showthread.php?t=65933Yes i am finally building something i WILL finish
Old 04-11-2012, 07:49 PM
2011 Post Whoring Champion
You might want to check this out:
http://www.scalemotorcars.com/forum/...stock-car.html
Same concept, bigger scale.
Nice work so far.
Old 04-13-2012, 07:01 PM
thanks CM-113 and Old Busted Hotness!
got some more work done on the car. got the interior decking in place with a hole in back for an inspection panel/ fuel fill up door. then got it all shot with some primer. looks good sitting in primer. no more soot from the lighter and pencil marks.
whole chassis sits right at 8" long
Old 04-18-2012, 06:25 PM
time for an
got the frame painted black. but had a disaster with the 2nd coat. it started bubbling and cracking. so now ive gotta strip the paint down and try again.
Also got most of the body made and mocked up. im gonna start calling this car Satan after all the headaches it has caused.
Old 04-20-2012, 06:25 PM
got some more work done. got the hood and scoop fabbed up, and finished up the roof. sprayed some black primer on it too. makes it look like a batmobile.
Old 05-01-2012, 09:56 AM
Gnarbeast's Avatar
Gnarbeast Gnarbeast is offline
the maverick
Member Number: 2251
Totally sweet! Late Models are awesome and yours is phenominal! Check out this link of a scale 1/7 rc late model http://www.dirtoval.com/forums/showthread.php?t=69319
Old 05-01-2012, 10:25 AM
got some more work done on this bad boy.
rear axle with link mounts and lift bar installed
hand grooved tires with chrome mud covers
front suspension installed. still need to make coilover shocks.
part of the motor painted and installed.
suspension will be glued in place to make it look as if it is 3 wheeling through a turn like the 1:1 cars do.
Old 05-13-2012, 08:00 PM
scalersince08's Avatar
scalersince08 scalersince08 is offline
mid level fab man
Member Number: 9697
this thing is cool man nice
Old 05-13-2012, 08:33 PM
Badd's Avatar
Badd Badd is offline
Dirty South
Member Number: 2330
Very nice job !!
Team A$$hole
Old 05-14-2012, 08:17 PM
thanks guys!
ive got some more work done on this car. finally got the rear suspension glued in and the body was repainted and glued on. also got it to where it would balance itself so the left front tire was off the ground like it is going through a turn.
