Old 04-27-2012, 10:32 PM
BaylorRae BaylorRae is offline
Member Number: 17649
Default Need LiPo Battery Charging Advice
I bought a Venom 5000mAH LiPo with a Passport 6s LiPo charger and the connectors don't match.
The charger's connector is a male deans plug (I think, not entirely sure)
While the battery is a female
But the battery came with a small adapter that will allow the two cords to connect.
Is this a safe way to charge the battery, or should I get a dean plug designed specifically for my battery?
Old 04-27-2012, 11:27 PM
SpecterXP's Avatar
SpecterXP SpecterXP is offline
Member Number: 7512
B/S/T Feedback: (15)
The adaptor is safe, but I suggest going DEANS with everything you have. Makes thing A LOT easier. I even wire my brushed motors with deans. I just switch the male-female so you can't plug the battery into the wrong place on the ESC. I can post pictures.
Old 04-29-2012, 07:10 AM
stewbaru's Avatar
stewbaru stewbaru is offline
Scaler, Trailer, Crawler
Member Number: 12471
Check your polaritys.
You DO NOT want to get those mixed up.
