Go Back   Scale 4x4 R/C Forums > Scale 4x4 R/C Trux! > 1/8, 1/6 and larger scale Trux!
1/8, 1/6 and larger scale Trux! Discuss your large scale projects here, 1/8, 1/6 and larger scales. Juggy, TXT, Clod, TF, MF and similar based rigs.
Old 05-03-2012, 07:20 PM
SwampDawg's Avatar
SwampDawg SwampDawg is offline
Still crawlin'
Member Number: 7204
Default Project RockClod
After digging through many bins of RC stuff, i managed to find a majority
of Clodbuster parts including both axles, wheels, tires, bumpers, links, soforth...
started by making this TVP chassis for it to start!
http://www.scale4x4rc.org/forums/image.php?type=sigpic&userid=7204&dateline=1300331  478
Old 05-03-2012, 09:14 PM
klampykixx's Avatar
klampykixx klampykixx is online now
Where did I go?
Member Number: 13899
Old 05-03-2012, 09:58 PM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
got the axles prepped and ready to go now, but question is....
2.2 wheels? lol
Here's the doners....
x2 Tamiya axles stripped down to the bare-essentials!
tommorow ill be fabricating the 3-link post mounts which will be fitted
through the center-top of the axle, where the old servo bellcrank went
through.
Old 05-04-2012, 04:01 PM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
got the top deck installed along with the EVX2 16.8v waterproof ESC!
Old 05-05-2012, 06:47 PM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
found some better stand-offs for my bodymounts!
much sturier then the threadrod/alloy bars i had on
it before.
Old 05-05-2012, 09:37 PM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
I couldnt believe it until i seen it!!
i didnt want to spend another 150.00 on a hardshell Yota then a buddie directed me to this Lexan shell for 30.00
http://store.rc4wd.com/Yota-110-Lexa...ody_p_511.html
This is goin on this Clod crawler
Old 05-06-2012, 12:11 AM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
Custom lower-link mounts for Clod axles)
Templates from Styrene.
Old 05-06-2012, 10:56 AM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
TEMPLATE
3-Link Post Mount
Here's the general design for my mount, still a little trimming to
do to make it look right but this is pretty much it.
A spacer will run through the hole in the axle and up into this custom
mount which is followed by a 3mm machine screw.
Old 05-12-2012, 12:26 AM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
Rising from the ashes comes RockClod
Finally got to the lower axle mounts using alloy, now atleast this rig is taking shape!
Old 05-12-2012, 02:07 PM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
Thundertech wheel widners and big nobby tires installed, all the lower end stuff is finished (spacers, screrws, nuts, threadlocked, etc...) Still need something 10mm thick to fabricate my custom 3-link post mounts. Just cant seem to find anything with this thickness??
Old 05-12-2012, 09:17 PM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
Dropped on my old Clod body (this is the larger scale lexan from ProLine)
and cut er up!
Old 05-13-2012, 03:22 PM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
looking at my custom lower link mounts, heres how they look
and are installed.
Chassis/Articulation
With body:
Old 05-26-2012, 06:57 PM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
made some progress today re: steering.
fabb'd up a servoplate to munt atop the front axle.
turned out great!
Old 05-27-2012, 07:05 AM
OldSchoolRC1's Avatar
OldSchoolRC1 OldSchoolRC1 is online now
Builder of low end high budget vehicles...
Member Number: 4701
Great looking clod build! Haven't seen those vintage pin spikes in a while.
Blessed are the flexible, for they never get bent out of shape
Old 05-27-2012, 08:53 AM
SwampDawg's Avatar
Still crawlin'
Member Number: 7204
worked late last night to finish the front end work.
now the servo is mounted (had to remove my plate and further mod it, had some glitches)
the 3-link post mounts are now integrated into the custom servoplate.
all i have now i believe are the rear 3-link post mounts.
as for the tires....yea, got these many years ago for a clod build but never got to it til now
*forgot too mention....the alloy piggyback shox seen in the images have been removed. They were up against the motor leads and this was a problem, so i opted for my stock savage shox using red coils. (actually orange but HPI are colorblind) lol
even though i knew these shox would give me alot more articulation i can still wanted the alloy piggybacks cuz its bling. But here she is with the Savage shocks and she has some nice twisty to er'
