Old 05-20-2009, 02:24 AM
Arcocustom's Avatar
Member Number: 2344
Smile
Originally Posted by freelife04239 View Post
yea the stalling wass due to a battery not having full charge. I recharged the battery and it was fine I think my old junk charger had a false peak or somthing. I recharged the battery and it was fine . Yea Im happy with how it climes it dose realy good on the steap stuff Ill know for sure when I take it to a good place to crawl. The truck at this point crawles way better than an rtr axial.
Glad to hear it was an easy fix. As for the battery false peaking, I would guess battery maintenance is to blame and not the charger. Those batteries need to be stored with a charge in them, then before using again, fully discharge the pack, then re- charge it to peak capacity. A 4000 mah pack, charged at 5 amps, should peak at around 50 minutes. Also, those batteries get hot charging and discharging. I run a fan on mine to keep the air moving and to try and keep temps in check.
Old 05-20-2009, 07:18 PM
freelife04239 freelife04239 is offline
Member Number: 7052
yea good idea i think ill start running a fan on mine to
