Old 02-03-2017, 08:58 AM
hairba11's Avatar
hairba11 hairba11 is offline
Rollin' in the winnie
Member Number: 4269
Thanks joe.
More progress
Old 02-03-2017, 05:50 PM
Coolaid202's Avatar
Coolaid202 Coolaid202 is offline
Sudbury Valley School is a place where people decide for themselves
Member Number: 2391
Nice work!
Is that one of the Fracture V8? Haven't seen one of them for a while. I almost bought one, then they were gone.
Looks like you will end up with a very short front drive shaft. Maybe just the angle of the picture makes it look that way.
-Never trouble trouble, till trouble troubles you.
Old 02-03-2017, 06:17 PM
hairba11's Avatar
Member Number: 4269
The front diff is right behind the grill, the front shaft will be about 3" long. The rear will be about 5"
Old 02-04-2017, 09:37 AM
hairba11's Avatar
Member Number: 4269
Another morning and some more progress
2.2 swampers, eritex comp solid wheels, fracture v8/trans/transfer, mad moose portal axles.
Ran it through the shot blast at work and got it primed.
Old 02-04-2017, 10:11 AM
Wow you progressed nicely in the last couple days! Looks mean already, can't wait to see the stance with the axles and tires on. Engine looks awesome in there.
Old 02-06-2017, 09:08 PM
hairba11's Avatar
Member Number: 4269
So a little weekend progress
Cage is black
I got the tires on the wheels. And figured out the bead ring hits the portals
Got my engine mount/subframe cut out of 1" X 1/8"
And got it mounted into the chassis with three 8-32 screws, and one broken off 8-32 tap
Old 02-08-2017, 08:39 PM
hairba11's Avatar
Member Number: 4269
Default Hairba11's 1:8 version of Hogan's Hot Rod (with Moose Portals)
Got my heim joints in
Old 02-09-2017, 06:47 PM
hairba11's Avatar
Member Number: 4269
Progress made on the suspension
I made uni-links for the axles
Old 02-10-2017, 09:24 AM
danielk's Avatar
danielk danielk is offline
I build Lowriders
Member Number: 1386
Ooh, I love it. 1-link suspension is my favorite.
Old 02-10-2017, 03:47 PM
hairba11's Avatar
Member Number: 4269
Thanks!
Got my front upper suspension mounts in, front shocks on, and panhard rod.
Old 02-13-2017, 01:24 PM
hairba11's Avatar
Member Number: 4269
Got some roller chain for my rear shackles. Welded it to the top of the axle plates
Got two more highlift shocks from klabeume and took out the internal springs
The suspension sits in droop in the rear
The front is in semi-droop. Only about 1/4" up travel.
I'm getting about 4" of articulation.
Old 02-14-2017, 08:15 AM
hairba11's Avatar
Member Number: 4269
Got drive shafts in an turned the knuckles around for BTA steering
Of course now that they're turned around they hit the lower shock mount.
Here's a detail inside the portal
Old 02-15-2017, 06:19 AM
Turning out fantastic.
Straight up crazy cool build.
Crazy crazy cool.
Old 02-15-2017, 09:20 AM
hairba11's Avatar
Member Number: 4269
I'll drink to that!
Used a brake lathe at work with the double chuck and a dremel with a carbide deburr tool to open up my inner rings and clear the portals
I moved the front lower shock mounts so the knuckles would clear.
This thing is awesome!
Old 02-15-2017, 10:23 PM
bluedually's Avatar
yes I can tow a house
Member Number: 12594
Sweet looking build, those portals look killer.
