Old 12-19-2009, 08:30 AM
malcolm malcolm is offline
Member Number: 10176
Default transmitter
hi to all i have an axial and i just bought a dig for ,my problem is what type of transmitter can i use for it how many channels,also would like to add four wheel steering.
thanks and hope that someboby can help me
Old 01-05-2010, 01:24 PM
Bulldog's Avatar
Bulldog Bulldog is offline
POWERHOUSE OFFROAD
Member Number: 10058
Default Adding text between pictures
I've seen a couple of guys that have text between uploaded images. how do I do this?
Old 01-05-2010, 01:42 PM
For dig you'll need a third channel, and for 4WS you'll need a fourth. Of course you'll want a winch, too, so that's five. If you can drive with sticks there are lots of choices; the Spextrum DX5e is only 99 bucks for 5 channels, spend a little more and you can get 6,7 or up to 14 channels (mucho dinero there). Winch, 4WS and dig all require a 3-position or proportional channel, depending on how you want to set it up.
Register with photobucket and copy the IMG code into your post, like this:
[ IMG]image location[/IMG]
Old 01-14-2010, 10:53 PM
mangledsavage's Avatar
mangledsavage mangledsavage is offline
Member Number: 7240
if your picture is in photobucket, put your mouse arrow over the picture you want to copy, then copy the IMG code and go into the reply box on here right click and paste!!
Old 02-07-2010, 05:33 PM
rc everywhere rc everywhere is offline
if it's got too much power that's perfect
Member Number: 8001
these things are realy funny! i think they are the greatest!
keep em coming!
Old 03-23-2010, 08:51 PM
Bulldog's Avatar
POWERHOUSE OFFROAD
Default Novak 55t
I had a problem soldering on my esc to my motor today....the solder just kept rolling off everything it might as well have been mercury!!!....any hints? Finally it took, but I wasn't sure why. I've sweat pipes before, but this is messing with me!
Old 03-24-2010, 05:54 AM
Need more heat. Hold the iron on the wire, feed a little solder right on the tip to get some heat transfer going, and feed solder in when it starts flowing. Do the same thing on the motor tabs, then drop the wire on while the solder is still hot. Put the iron on the wire and hold it there til it all melts together.
A good 60w iron should be all you need.
Old 03-24-2010, 12:26 PM
The Stray Cat's Avatar
Everybody Needs Rock N Roll
Member Number: 4514
B/S/T Feedback: (45)
It could also be caused by residue or something on the wires, also as OBH said "tinning" the leads helps greatly.
Old 03-24-2010, 02:14 PM
Thorsteenster's Avatar
The 4rd prize winner!
Member Number: 990
Tin everything, clean and tin the tip, wires and motor tabs. Make sure the wire is nice and shiny fresh copper, cut it back if need be.
www.varcoffroaders.com
Old 05-02-2010, 10:38 PM
Bob83 Bob83 is offline
Member Number: 11490
Old 06-12-2010, 10:04 PM
rcdave13's Avatar
rcdave13 rcdave13 is offline
Not A Newbie
Member Number: 12015
How do I quote a post with a pic in it?
Old 06-12-2010, 10:14 PM
at the bottom of the post you will see a box that says ''quote''. click on it, and it will transfer the text and image code into your reply box. then simply post what you want after it.
Old 06-13-2010, 01:44 AM
sk8te-penguin's Avatar
♫▂▃▅▆MONSTER ENERGY™▆▅▃▂♫
Member Number: 1370
It doesn't work with attached images though.
Old 08-19-2010, 10:35 PM
bigdave15's Avatar
bigdave15 bigdave15 is offline
dont touch the triem
Member Number: 12609
how scale would a crawler king be
Old 08-20-2010, 04:33 AM
As scale as you want to make it
