Old 12-05-2009, 09:27 PM
traxxas4fun's Avatar
traxxas4fun traxxas4fun is offline
Member Number: 9546
Default cc-01 scale body list or anything?
is their a cc-01 scale body list or anything out their?
im looking for trucks,samurai,cherokee/xj.. really anything but a pajero..
im looking at lexan and regular hard plastic..
does anyone make bodies for these, like proline etc.. whats the cc-o1s wheelbase?
Old 12-05-2009, 09:28 PM
A32Limited's Avatar
A32Limited A32Limited is offline
<insert clever title here>
Member Number: 9003
There's no specific bodies for it, but if you measure out the track width and wheelbase, that'll give you a good starting point.
Old 12-05-2009, 09:34 PM
Member Number: 9546
track width, is that from center of front wheel to center of rear?>
Old 12-05-2009, 09:36 PM
A32Limited's Avatar
Member Number: 9003
Nope, track width is from the outside of one tire, to the outside of the other tire. Wheelbase is from hub to hub.
Old 12-06-2009, 04:05 PM
Member Number: 9546
ok, its 13inches from the back of the rear fender to the front of the front fender... its been cut, but doesnt loook bad..
Old 12-06-2009, 04:06 PM
Member Number: 9546
the f350 or tundra body dont fit do they?
Old 12-06-2009, 04:09 PM
A32Limited's Avatar
Member Number: 9003
Yeah, both of those bodies will fit, it will require you to lengthen the wheelbase by making new links, and extending the rear of the chassis so the shocks are at the same angle as they are stock.
Old 12-06-2009, 04:10 PM
Member Number: 9546
how do i find out the track width of these bodies, like i see some proline blazer bodies i like but i dont know if they fit?
how much are we talking lengthening the chassis by with the tundra or f350
Old 12-06-2009, 06:13 PM
pantablo's Avatar
pantablo pantablo is offline
Mr. Tire Guy
Member Number: 3012
Nissan Hardbody lexan shell works on the cc01. I have one of these I'm not using Id sell. not painted.
LR3, Range Rover Sport by Newbright work on cc01.
Tamiya brat works
the defender body works.
Pablo
Old 12-06-2009, 06:21 PM
96dak's Avatar
96dak 96dak is offline
Member Number: 9708
If I remember right, the parma 1972 chevy c10 doesn't have molded in wheel arches, so you could just cut them to the wheelbase you need. I have a Ta-02 with that body and the track width works well.
Here's the dimensions for the proline blazer:
Length:17.3" (440mm)
Width:6.8" (172mm)
Height:5.6" (143mm)
Wheel Base:11.2" (285mm)
right off the proline website: http://www.prolineracing.com/product...dy-150-26.html
Hope that helps!!
Old 12-06-2009, 06:49 PM
ou812 ou812 is offline
FlatBrokeCustomz
Member Number: 2317
I used a proline blazer body on my cc-01 but I extended my rear links to match the wheelbase,also extended the driveshaft
Old 12-06-2009, 07:33 PM
Member Number: 9546
thanks! how far did you have to extend everything ^^
Old 12-07-2009, 10:56 AM
civicex5speed's Avatar
civicex5speed civicex5speed is offline
Member Number: 9756
I am currently building my CC-01 (FJ40) and would likly be extending my wheel bace for another body. How hard is it to do this? Can I just use a tube to extend the drive shaft?
Old 12-07-2009, 11:26 AM
pantablo's Avatar
Mr. Tire Guy
Member Number: 3012
If you bought the cc-01 FJ40 kit you wont need to extend anything. The kit will come with all the parts and tell you where to install them for the right wheelbase. The cc01 chassis has two settings on the chassis, a short wb and a long wb setting because they use the same chassis for several kits.
The wheel base settings are 9.5" and 10.5".
If you're doing a custom length you need to make new links and a driveshaft.
If you have a short wheelbase setup and want a long wheelbase you need to replace the driveshaft (either with a long wheelbase one from a Touareg or make one up from Traxxas shafts) and move the links to their other mounting position.
Pablo
Old 12-08-2009, 02:55 PM
labreck67's Avatar
labreck67 labreck67 is offline
Member Number: 9530
hate to be harsh, but around here the search button will be your friend. If you don't learn how to use it, people will not be so nice.. just some advice
cheers
