Old 03-04-2017, 05:31 PM
Test fit the steering servo and the Traxxas transmission. I want to keep the motors up front so they get plenty of air.
Test fit the transmissions, will have good ground clearance and shallow drive shaft angles.
Old 03-04-2017, 05:40 PM
Old 03-05-2017, 09:23 AM
350TacoZilla's Avatar
So you can crawl these little things? LOL
Member Number: 2402
nice you staying with leaf springs up front and coilovers in back or is rear getting the leaf spring treatment too?
Old 03-05-2017, 10:11 AM
4 link and coils in the rear... Its sort of scale since they are leaf up front and air ride out back, at least the few I have seen.
Old 03-11-2017, 09:12 PM
Got started on the sub frame for the HPI trans and what the rear axle links will mount up too. Also left some material in front of the trans incase I switch to 4 link in the front or need to run traction bars to keep axle wrap under control.
Old 05-22-2017, 07:26 PM
Wasn't happy with the rails I had, so built new ones. Video here
Old 05-22-2017, 07:41 PM
Got the HPI trans mounted up. With the long drive shaft I could tuck it up in the frame a little better.
Of all the screws I have, I don't have the right size to bolt the Traxxas unit in
Old 05-24-2017, 08:05 PM
Built the sub frame for the rear 4 link. Haven't bolted it in yet as I need to get the body mounted so I can set the wheel base. Hoping to get it sitting on springs at all 4 corners this weekend.
Old 05-25-2017, 08:27 PM
Tinkered with some body mounts, they need more tinkering. Did figure out a solution for the much needed carrier bearing. This thing is so long, it will have to have 2 rear drive shafts. Just need to fab up something to keep the steering knuckle turned carrier bearing from pivoting and it will be good to go.
Old 05-27-2017, 09:52 PM
First plan for the traxxas transmission mounts wasn't going to work, but figured out something different. Its getting closer to being a roller.
Old Yesterday, 05:55 PM
Rear cab mount done and rear axle and 4 link bolted to the frame. Those 5 inch tires look kinda small lol.
Old Yesterday, 09:45 PM
Another build video
