Old 12-26-2009, 05:50 PM
Default 1:6 Kaiser 60's CJ-6
Been working on this idea for awhile. I started to do "another Willys Jeep" build but decided on something a little different, a mid 60's Kaiser CJ-6.
After seeing the styrene work of some of the folks here, I have been inspired to build this from the ground up. I'll post some pics tomorrow of my current progress, the wife is using my camera tonight.
Here is what I'm looking to get to...
Old 12-29-2009, 09:34 PM
Default 1:6 Kaiser 60's CJ-6 UPDATED, **PICS**
I finally got my camera back...finished transfer case mount and skid plate while waiting for it.
Doesn't have a whole lotta articulation, but neither did the original 1:1. I think I've got the chassis pretty close to how a 1:1 actually worked. I kinda got the steering close...needs a little more tweeking. All that's left to do before I start the body is the body mounting brackets...probably get them done this weekend.
Let me know what you think...
Old 12-29-2009, 10:01 PM
chevy55's Avatar
chevy55 chevy55 is offline
Member Number: 4174
Nice fab work!The frame looks great.
Don't you know I'm Broke MoFO # SEVEN-O
Old 12-29-2009, 10:41 PM
summitboy's Avatar
summitboy summitboy is offline
whats a manual?
Member Number: 10344
thats awesome and amazing frame work. from seeing the 1:1 pic i would move the roll bar back more to give it a cleaner look.
Old 12-30-2009, 01:59 AM
lemecanodejante's Avatar
Scale is good!
Member Number: 1144
awesome work!!!!!!
Old 12-30-2009, 11:23 AM
utieh's Avatar
utieh utieh is offline
Member Number: 1407
B/S/T Feedback: (9)
Amazing work, love the frame. you realise that most 1/10th stuff is actually too big for that scale, but it works almost perfectly on your project.
Old 12-30-2009, 09:53 PM
I agree...the cage is not quite what I want. This is what I will try to replicate...
Old 12-30-2009, 10:09 PM
Thanks for the kind words. I will try to keep updates coming regularly.
The frame is cut from solid 5/16" thick T-6 aluminum. Strong for aluminum but tough on drill bits and taps.
All the frame joints and spring hangers are drilled and tapped for 3mm screws. Springs were made from mower recoil spring, even with 3 leaves they are still soft enough for flex. Without the shocks, the frame weight flattens them out so I may need some softer springs for the shocks but I won't know for sure until I get all the radio gear and body on it.
I'm going to work on the body brackets this weekend. Also want work on the rear bumper. Should I put the old style rear drawbar on it or a custom rear bumper similar to the Westins?
Old 12-30-2009, 10:40 PM
SCRT Pilot's Avatar
SCRT Pilot SCRT Pilot is offline
All bad things come to those who haste
Member Number: 10251
I like it, you did a great job.
Only thing is, I would reinforce the damper mountings on the frame. They seem to bend already (last pic).
Old 12-31-2009, 01:59 PM
Actually, there not bent, my mount area on the frame is slightly off-square. Thanks for pointing that out, I was going straighten it out, but forgot before taking the pics. I'll add this to my to-do list this weekend, photos will follow with the angle corrected.
These mounts are strong and I have not even been able to tweek them at all. The soldering works well...
Old 12-31-2009, 03:12 PM
mar618 mar618 is offline
Member Number: 9163
excellent work going on,cant wait to see more
Old 01-06-2010, 02:01 PM
Default Updated 1/6/10
Well I got the damper mounts corrected, body mount brackets completed, and built the rear drawbar.
That just about finishes the frame, except I want to add sliders to it. I have to wait till the body tub is done first - styrene is on order. I had to order from a couple of different places to get the sizes I wanted. Can't wait to start...here some pics for the updates.
Old 01-06-2010, 02:08 PM
gmanwheelin's Avatar
gmanwheelin gmanwheelin is offline
10 rc's=6 on going builds 2 runners 2 shelf queens!
Member Number: 7117
love the fab work!
Old 01-06-2010, 05:55 PM
hugybear's Avatar
hugybear hugybear is offline
Member Number: 6112
lookin good
Old 01-21-2010, 12:40 PM
IKke's Avatar
IKke IKke is offline
Oh hai!
Member Number: 5041
Looks nice , what kind of tires do you have there?
