Old 09-19-2010, 11:56 AM
bluedually's Avatar
yes I can tow a house
Member Number: 12594
Smile CXT build
Got a little start on building the CXT. I am using HPI Wheely King running gear. Aluminum C-channel for frame rails. Still have yet to figure out what tires and rims to run on this project. I was going to try a scale build, now it is going to be more of a performance/custom scale-ish build.
how close the width of the hpi and the new bright are
Pretty close by Gordon Latimer, on Flickr
Paint
CXT Paint 1 by Gordon Latimer, on Flickr
I don't have any pictures of the frame yet. I have to do a little work on my real truck. Than I will get some pictures and more work done on the chassis.
Old 09-29-2010, 01:48 PM
Bulldog's Avatar
Bulldog Bulldog is offline
POWERHOUSE OFFROAD
Member Number: 10058
Great paint on there!!!! Looks like a fun rig
Old 09-29-2010, 05:34 PM
bluedually's Avatar
Got a little work on the frame done, need to snap some pics. Any suggestions for wheel and tires? They need to be around 6 inches tall and no wider than 3 inches.
Old 09-30-2010, 09:01 PM
bluedually's Avatar
Got the body back, and since everyone else sets the body over a set of tires with no drive line, I might as well too. Actually the 5.5 inch tires the wheely king rolls on don't look to bad. Might go with some 2.8 rims and a more scale 5.5 tire. Let me know what you think. I am leaning to the shorted stance and make it kind of a muscle truck.
Old 10-01-2010, 03:50 PM
John82601's Avatar
John82601 John82601 is offline
Direction, then velocity.
Member Number: 7933
That looks great. Your buddy did an awesome job on the paint. I think I'd keep it an offroader with some 2.2 Roclox or 2.2 PL Swampers. The Lox are a little taller of the two but I love the look of the Swampers.
Old 10-01-2010, 05:25 PM
bluedually's Avatar
I was thinking either the Lox or the swampers.
Old 10-02-2010, 07:53 PM
bluedually's Avatar
Pics of the frame, finally I know. Aluminum C channel for the main rails and aluminum angle for the cross members. Going to run leaf springs instead of four link. Mainly because they are simple, and a little more scale.
cxtpart2 (3) by Gordon Latimer, on Flickr
Old 10-03-2010, 05:41 AM
4x4 dixie rebel's Avatar
4x4 dixie rebel 4x4 dixie rebel is offline
Extreme Mudding In The South!!!!!
Member Number: 5984
looks great
IF IT DONT WORK..DUCK TAPE IT!!
Old 10-14-2010, 06:18 PM
bluedually's Avatar
Got the motor and trans mounted up today. Need to get to the LHS and order some springs and spring hangers. Might put a four link in the rear, there is more clearance between the bed floor and the frame than I thought.
The batter box is going to mount under the tilt bed. Mainly for convenience then anything else.
Old 10-19-2010, 04:00 PM
John82601's Avatar
Member Number: 7933
Sounds like a plan. I can't wait to see pics with the suspension mocked up.
Old 12-08-2010, 02:37 PM
bluedually's Avatar
Little update, trans is mounted and the front leaf springs are bolted on. I am really pleased with the stance.
from the front
Transmissions by Gordon Latimer, on Flickr
Going to redo the leaf spring mounts. So I don't have the axle mounted with so much lift block. by Gordon Latimer, on Flickr
Old 05-07-2011, 02:33 PM
repoman37's Avatar
repoman37 repoman37 is offline
Member Number: 13653
Any updates on this build? Before I found this build I started almost the same thing. Body and frame and axles. Few tricks up my sleeves though. As soon as I figure out posting pics from my phone I will. Only source of internet for me.nice build so far.
Old 05-22-2011, 02:28 PM
bluedually's Avatar
No updates. Life got in the way as it some times does. Still hung up on the leaf spring mounts. I have an idea if I can ever get to the store to buy some aluminum solid stock. The last three weeks I have worked 11 - 12 hour days and get off after every place is closed.
I am thinking of using a 3 speed trans off of RC4wd and put the HPI trans in the bruiser frame I have.
Old 01-15-2014, 06:37 PM
bluedually's Avatar
Well I completely forgot about this forum and build thread....
Had to scrap the aluminum channel frame, just wasn't going to work the way I wanted it to. Got some sheet metal and I am making a different style of frame. I will get some more pictures later this week.
Old 01-18-2014, 01:58 PM
JBandit03's Avatar
JBandit03 JBandit03 is offline
The Ogre
Member Number: 12336
Looks good. Cant wait to see how this turns out. I have been working on building my 1/6 CXT here lately out of a Ground Pounder. Been meaning to make a post, but havent got them uploaded yet.
