Old 01-02-2014, 11:18 AM
86K10 86K10 is offline
Member Number: 21407
Default Cutting chassis?
I am using 1/2" square tubing for my chassis. Got it all bent shaped, measured and drew a line up the center and now need to cut it evenly from end to end. I have a hacksaw, Dremel with a cut off wheel and hand held jigsaw. I do not have a band saw.
What is the preferred method to split it evenly?
Thanks.
Old 01-02-2014, 11:31 AM
8BALL's Avatar
8BALL 8BALL is offline
Member Number: 9396
very hard... I would not count what I say as how it is, but I would use masking tape to make the line down the middle and cut very very slowly down the edge of it as a guide. or you could clamp something on top and saw down the edge to stop it wandering off?
Old 01-02-2014, 12:51 PM
Built2Bash's Avatar
Built2Bash Built2Bash is offline
Playing around at Stark Industries
Member Number: 11880
Well, given what you have...and hoping you have a vice to use, you could put the jig saw upside down and clamped in the vice and proceed to cut (BUT BE CAREFUL ITS EXTREMELY DANGEROUS). Second option would be to put the tubing in the vice and cut it with the dremel, but be prepared to have a great deal of patience because it wont be quick. But always remember to factor in the width of the blade because it will take it out of the material...so cut exactly ON the line to end up with two equal halves.
Old 01-02-2014, 01:16 PM
Ok. Good points. Was not sure about the jig saw, agreed it sounds dangerous. Dremel was my preference. Patience will be the key and cutting right on the line. Appreciate the info.
Sounds like I am on the right track. Oh, and definitely using a vise on my work bench. It was my friend when I was heating and bending the metal.
Old 01-02-2014, 01:53 PM
I'd clamp it in the vice and use the jigsaw. Slow and careful, and clean up the cuts with a file.
Old 01-02-2014, 02:35 PM
Built2Bash's Avatar
Agreed that it's definitely not the safest route to go but when you're in a pinch and need it done...haha...can't say Ive always erred on the side of safety.
Old 01-03-2014, 07:47 PM
Gaspard de Coligny Gaspard de Coligny is offline
Member Number: 4548
The jigsaw trick sounds nice. And not so deadly if held properly.
In my book jigsaw are a bit safer than bandsaws and much safer than circular saws
