Old 03-14-2019, 04:40 PM
scaleraddict scaleraddict is offline
Member Number: 20917
Originally Posted by 2redrovers View Post
I think you may have rear traction issues with that setup hehe
But seriously, it's really coming together very nicely indeed
*4 thumbs up*
Thanks! Maybe I should add more wheels to fix it
Originally Posted by frizzen View Post
Printed parts are looking great, which plastic'?
Thanks! They're PLA. I know, I know, it's the weaker filament but the parts seem solid. Will upgrade when these break
A better look at the road wheel
  #47
Old 03-15-2019, 04:47 PM
pfffff...I'm "exhaust-ed"
there's more than one kind of stack for this truck. I went with this one because is easier to add a smoke generator in the future
This one is for the intake:
Also made the bezels (?) around the stacks like the 1:1
Old 03-16-2019, 04:27 PM
Quick mockup now that i have half the wheels painted
Old 03-16-2019, 08:09 PM
That thing is going to be unstoppable
Old 03-17-2019, 06:10 AM
metal on the floor for whatever reason
Detail,those are M2s
All assembled:
were made in 4mm stainless steel rod, TIG welded and the brackets are from 12mm square tubing. Ran out of M2 nuts in the middle of the assembly
Old 03-18-2019, 05:16 PM
Not really an update..
So,I was thinking to put a sound generator so first I had to see how a M548 sounded like. I was expecting a big diesel truck sound but...
...holy cow, it's like 100 angels riding chainsaws
Talking about motors, this it's how it looks a 540 on one of these gearboxes(came with a 370)
Old 03-19-2019, 03:25 PM
talking about sound:
first test. not everything is working properly. Sometimes I lose the reverse on one ESC
Old 03-19-2019, 04:25 PM
Old 03-20-2019, 01:52 PM
I'm turning my attention to the tailgate now. Added the steel tow cable with all it's mounts
Sure it will look better all painted(and without excess glue) but i want to show it earlier. For the curious, there's aluminium for the half circles and hooks , copper on the middle mount, brass on the cable ends and the cable itself it's steel(a bike brake cable)
Old 03-22-2019, 05:26 PM
Hi guys!
Working on the ring mount and legs for the .50. It's a notorious feature that had to include..
The ring it's a 2 piece part that I've machined earlier. Could do it in 1 piece but this way, rotates 360.
First, the front legs
Then,could do the rear ones
The asymmetry on these is on purpose.For some reason the 1:1 it's like this...
Waited to next day to allow to epoxy to harden and added reinforcements,steps and cleaned the "welds"
Only needs a bit of sanding,colour and better looking(and shorter bolts). I think I'm doing the .50's mount next...
Old 03-22-2019, 09:59 PM
Shame you won't really be able to make that .50 turret rc function and still look scale. Or is that a possibility? Doesn't need it because the details are awesome but it would be so cool to see the gun rotate by magic.
Never having seen one, would the asymmetric legs be to accommodate the ammo feed or maybe so the operator can stand out of the drivers vision?
You nailed that tow rope!!
Old 03-23-2019, 03:57 AM
Honestly, I've no idea of the reason why is assimetric because the ring itself it's centered on the cab.Know that the ring mount model (M66) is shared with other trucks but the legs are specific to the m548. Those platforms on the front legs are for storing ammo boxes(I thought that were steps)
I've never considered motorizing the machine gun but everything is possible down the road..
Thanks, I'm very proud of the tow rope and the rest of the tailgate
Note: my cargo area it's different than the photo above because it has the optional flat metal sheets,depending on the cargo,like this:
It made it much more easier to make and hide stuff under
Old 03-24-2019, 06:30 AM
The cutoff swich
And then, the handles(?) to help enter the cab
Some creative liberty to make them work with the door handles
Also...painted the last 5 road wheels
Keep tuned guys,it will go hardcore from here....
Old 03-24-2019, 02:14 PM
Lurch Lurch is offline
Newbie A++
Member Number: 27326
Go hardcore? Man I think your well past that already!
Old 03-25-2019, 05:12 PM
Wombii's Avatar
Wombii Wombii is offline
Styrene apprentice
Member Number: 5663
You're doing amazing work here! Is it an engine or full electrical cutoff switch on the real thing?
Styrene project: Scania Rosenbauer airport fire truck - http://www.scale4x4rc.org/forums/showthread.php?t=82630
