Old 04-29-2013, 08:37 PM
Default CC01 Build #2 (2.2 build)
and on to build #2 - WILD! The mild build is done and in the 1.5 section. It was nearly so stock looking, it hurt. So this one is going to a bit...out there. Goal here is to push the boundaries of the CC chassis.
This chassis was pretty hacked up from the PO, so I had no qualms about hacking it further.
Chassis got a major haircut:
Front skid shaved down and TL01B arms added:
Front and rear suspension..rear axle is shimmed, and a 3 point truss added. Needed a little more strength here then the Jeep so went with a rear brace here. Spacers added to match the front track.
More to come.
Old 04-29-2013, 11:05 PM
Louisbaby's Avatar
Whooooosh....
Member Number: 10023
Yip, I'm subscribed...
Old 04-30-2013, 12:11 AM
bonards29's Avatar
bonards29 bonards29 is offline
Member Number: 4236
B/S/T Feedback: (14)
Love ifs builds! Will be watching for sure!
Old 04-30-2013, 01:42 PM
axialjohan axialjohan is offline
Member Number: 19326
Cool project!
Greetings Johan
Old 05-11-2013, 10:07 AM
Put on a set of 2.2's and there was no way they were going to clear. So I narrowed out the wheelwells.
Hacked off the rear of the wells. Kinda tricky as it's close to the gearbox cover.
A little plastic weld and some styrene later...tried to follow the contours of the chassis as much as possible. Looks a little rough, will spray the chassis black later to blend it all together. Do have a bit more fill to do here too.
From the top compared to a stock chassis. Much narrower now - should clear up to about a 5" tire now at full lock.
Time to work on the bottom. Did a bunch of dremeling and fab work this morning. Wanted to get rid of the driveshaft hanging down, and get as much of a flat bottom as possible.
A Highlift chassis steering block was a perfect fit.
Now that I had room, fabbed up a set of skids for the bottom. The drivehshaft cover will be welded on later.
Old 05-11-2013, 10:13 AM
The-Gamer's Avatar
The-Gamer The-Gamer is offline
O tuga
Member Number: 9097
B/S/T Feedback: (19)
Wow!! That skid is simple awesome, sir!!! Nice job!!!
Old 05-11-2013, 12:06 PM
Louisbaby's Avatar
Whooooosh....
I'm going to copy that Highlift part idea. You're a genius. Plate work on the bottom is amazing.
Old 05-13-2013, 07:09 AM
That part worked out perfectly! Had that in mind for a while, just never had a build to use it on.
Old 05-13-2013, 02:55 PM
minizmodder's Avatar
minizmodder minizmodder is offline
Master of my domain
Member Number: 12436
B/S/T Feedback: (10)
I love it, this isn't your avarage bolt on aluminum bits and call it a project type build
Old 05-13-2013, 06:56 PM
joe's Avatar
joe joe is offline
RCMT'er
Member Number: 1944
Awesome! This is great man.
Great use of the steering block.
http://www.scale4x4rc.org/forums/image.php?type=sigpic&userid=1944&dateline=1222116  369
Old 05-13-2013, 08:23 PM
Pushing the limits of the CC chassis on this one for sure. Goal is to stuff a set of Pitbull I's on here, or maybe some TSL's. We'll see.
Just went nuts on Asiatees. Pretty cool site for some of the more obscure hop-ups. Some blue stuff is on the way, and a whole load of TA parts. Forgot the CV's for the front though...next time.
Old 05-21-2013, 08:47 PM
Been waiting for a pile of parts...got all in but one. Bunch of aluminum goodies for the front and 2 set of Junfac shocks.
Wahoo!
Wild Dagger arms, TA02 knuckles and C's, and 103mm shocks. I looked high and low for a body to fit this rig,and found a pretty good one that I thought might work. Of course, that didn't work out at all, so I picked up a Buggy Champ body with fingers crossed and started hacking. Think it'll work with some serious mods. Good to keep it in the family too.
All mocked up really, just getting a feel for it. Liking it so far! Still waiting on a few odds and ends so I can assemble it for real and get busy with suspension mounts and body work.
Old 05-21-2013, 11:12 PM
Louisbaby's Avatar
Whooooosh....
I really like the direction this is going in...
Old 06-05-2013, 08:44 AM
Wauw, very nice job!
Greetings Johan
Old 06-05-2013, 11:21 AM
ddtuass's Avatar
ddtuass ddtuass is offline
I never leave, but my wife did!
Member Number: 10
Looking good.
