Old 06-18-2013, 09:38 PM
Default Dual Wraith build
Bought a Wraith kit when they first came out and had a ton of issues with it - so much so, I got frustrated and basically sat it on the shelf unfinished. A few weeks ago, i finally got off my duff and finished up and drove it once. Not bad. Then, a trade deal came up for my Slash, and I ended up with a second Wraith, came with a Timbuk2 system (not bad) and a few other small mods. Ran the pants off that truck, and had a blast. Was run hard before I got, so it was in need of a teardown and inspection, and while I had it apart, I decided to mix and match parts from both rigs and do a rebuild on both. One will be for rocks/trails, and the other a little more high speed backward terror. 2 very different set-ups.
Enough blather, let's get some pics up: Here's where I was a week ago...
Busted out the wrenches and started tearing them down...So now let's get building - First: the rock rig.
Built up the bottom end. Lower links were replaced with 8/32 thread, uppers are standard Axial aluminum uppers, and all the plastic balls were replaced with metal upgrades. 3 Racing "CR01" shocks (VERY nice for the $$) with black Axial springs and 40wt oil. STRC steering links added and are swung by an 645MG - came on the truck will run it till it blows. Replaced the usual C hub screws with some machine screws, and shimmed up all the links. Not sure why Axial builds so much play into them - drives me crazy. No play now, nice and smooth!
Having blown my entire years budget pretty much on a Bruiser, won't be a lot of flash on these rigs. Don't expect a lot of aluminum porn here. Splurged in a few key places though Tekin ROC 3100 and MMP with field card.
Timbuk2 was fine, but wanted a bit more.
Before going out and dropping some coin on new shafts, figured I'd give the stockers some beef and see how they hold up. 7/32 Brass tubing coated in JB Weld and shoved in there. Works well on other rigs, we'll see how it holds up here.
More to come
Old 06-19-2013, 07:17 PM
Sweet.....I have wraith on the brain so bad right now, I'm selling other builds to by more...ha. I'm tuned in and watching.
Old 06-21-2013, 08:15 PM
Leaelita2 Leaelita2 is offline
Member Number: 19907
Hi,
I just got my first wraith kit, it's all standard at the mo, will upgrade parts as they fail. I pushed some 6mm threaded bar in to my drive shafts after reading on here that they collapse, i cut a slot in the end so they can be unscrewed if required. I can see a lot of cash being spent on mine in the future.
Cheers,
Tim
Old 06-24-2013, 12:14 PM
Welcome to the hobby...lol. Believe me, it's the way it goes.
Been building decks, not a lot to update.
I was planning to swap electronics and go, but of course, went overboard. Stripped it down and sprayed the chassis metallic black so it looked a bit different, and ordered a new body while I was at it. Just starting reassembly. Moving the ESC to the back, it was getting a bit crowded under the hood.
Got some new 103mm Gmades on the way - it came with TRX big bores, but don't like not having a pivot ball on them. Just annoys me. PO's solution was to loosen the shock mounts so it can all flex. Don't like that at all.
Wrestling with picking up a new set of axles, but no need really - the stockers are pretty tough. Some of the holes are stripped out from the PO though, so will need some new cases at minimum eventually. MUST RESIST!
Old 06-25-2013, 06:17 AM
For the rocker Wraith, I had planned to just swap the electronics and go, but of course, that never holds. Stripped it down and sprayed the chassis with some black metallic just to set it apart a little bit. Came out pretty nice imo. Ordered a new body as well.
And while the paint was drying, spent a little time on the basher. Swapped over the body panels that came on the other one and fast backed the rear. Swapped out the lockers for diffs front and rear, got a set of swaybars set up and pretty much get the chassis work done. Picked up an STRC motor plate and did a 32p conversion while I was in there.
Should have a bit lower stance when all is said and done. Have since swapped the shocks since I took this pic.
Old 06-27-2013, 09:25 PM
Got a driver in the crawler...Love it!!
Mounted the ESC in the back and wanted to hide it somewhat...so made a few mods to the battery tray with some styrene and closed it all in. Hides the ESC (leaves the fan exposed for some air) and leaves some room for some scale goodies. Came out pretty decent imo.
Old 06-28-2013, 06:03 AM
OOH man these are turning out sweet oldschool... Frigging fantastic for sure. Hows the wrist after all them screws...I trimmed the ends off some old Allen wrenches and use a cheapy lil batt drill so I don't strip the holes out. Keep the post coming......
Old 06-28-2013, 07:46 AM
I use hexes that slot into my power drill. best investment ever. Having said that I built one a long time ago, and traded for the other so not a lot going on.
Took me an hour to get Stone Cold in there. Had to do some serious trimming to fold him into the seat. Arnold will be driving the basher
Old 07-03-2013, 06:16 AM
OK, so I could not help myself. Couple goodies from RC4WD, VP, Junfac and STRC bolted on. That whole thing about not spending a lot of cash - right out the window! Went with the silver ilo black for a little show and go factor. Taking this rig camping in a few weeks, and it always get peoples eye. I've got 3-4 other people into RC over the years.
Pretty pleased with the parts fit- everything went together nice and smooth.
Next order will be beefier driveshafts, R&P's and lockers. But for now, ready to bolt it together and go play!
Old 07-06-2013, 05:09 PM
Finally seeing the light at the tunnel for both rigs. Both are standing on their own finally.
The "basher" is coming along well. Electronics are in:
Driver installed:
Final stance...didn't like the orange on the body panels, so took it all off and they are getting a coat of black:
"Crawler" is finally standing as well, just waiting on a servo:
Has Pitbulls on now and really like them. Have some other wheel choices on standby:
Tight fit!! But the shocks feel great.
Old 07-21-2013, 10:22 AM
Well, the "basher" Wraith is ready to go. Didn't bother with a ton of details, slapped on some paint and wheels and it was playtime. First time I've ever really beat on one of these.
Hauled pretty good....the Castle 4 pole was a pretty good match for this truck. 95 degrees with aggressive gearing and no thermals or any other problems. The diffs and swaybars made all the difference really, handled great all around. Much better than I expected for a solid axle rig. Wasn't very easy on it for sure...and it took to the air like a champ.
Carnage. After 2 packs, it was time to pack it in. I'm usually pretty gentle with my rigs, but I was having such a good time I pretty much let loose. Popped 2 beads, lost a swaybar, demolished the servo (used 645MG, knew that was going to happen) the slipper was really slipping towards the end, and the rear braces popped. Fun time though!
Old 07-21-2013, 12:09 PM
LDTREDNECK LDTREDNECK is offline
Member Number: 19413
Beautiful builds!
Old 08-09-2013, 08:39 PM
Thank you sir!
Wraith # 2 is finally done. (Wraith 1 has already been torn to pieces, but that's another story)
Some last minute upgrades to handle the ROC.
Painted...I did a "texture" on the silver, think it came out pretty good. With the painted cage, looks a bit different from other wraiths. Subtle, but I like it.
And a few finished pics. Few more odds and ends to tie up (forgot to order the light set with the light bar) but I'm loving it. Baddest rig I've ever built, bar none.
Drove like a champ. The ROC is amazing...it's a straight up beast on 2S, I cannot imagine it on 3S.
Old 11-11-2013, 09:58 AM
Jeff@TireBalls Jeff@TireBalls is offline
Member Number: 645
Ok, you gotta tell me where you found Arnold, he's bad ***!!!
Old 03-04-2014, 11:29 PM
n8welch's Avatar
n8welch n8welch is offline
Member Number: 19716
Yes where did you find Arnold???? Ive got Rambo but I want Arnold too.
