Go Back   Scale 4x4 R/C Forums > Scale 4x4 R/C Trux! > Agricultural and Industrial Equipment
Agricultural and Industrial Equipment A place for your agricultural, industrial, and other heavy equipment builds!
Old 02-04-2019, 05:21 PM
Man that sucks harder than vacuuming up bowling balls.. I'd say exactly what i think of YouTube and their tactics but it's not polite to say that many four letter words.
  #1142
Old 02-05-2019, 06:16 AM
Lil Giants's Avatar
Lil Giants Lil Giants is offline
JOE
Member Number: 1683
Wanna see some sick utube monetary stats... came across this link the other day
https://socialblade.com/youtube/
Old 02-05-2019, 07:02 PM
I am pretty sure I don't want to know what they posted to get 60 trillion views.
Old 02-09-2019, 01:38 PM
Lil Giants's Avatar
JOE
Member Number: 1683
Old 02-10-2019, 06:57 AM
Apparently a round boulder doesn't fit in a square hole
Old 02-10-2019, 07:12 AM
Lil Giants's Avatar
JOE
Member Number: 1683
And that rock was rather porous too, I'm sure it would've crumbled easily.
I dropped the pup, then bound the two B50's together on a DX8 radio & drove them up the incline simultaneously.
I learned something from this video... 4 brushed motors on one esc, like a front loader or tractor, works fine; but 6 motors on one esc in the ADT, kinda wonky!
I always thought since the 1st run of the newer B50 that it didn't seem to pull the incline quite right; and now without the pup I see why. Time for some rewiring.
Old 02-11-2019, 09:56 PM
Lil Giants's Avatar
JOE
Member Number: 1683
Maybe next month have a vid of the lil screener; vibra screening large lumps & rocks right now.
If you noticed in the last video @9.10, the painted cab ADT struggled to get out of the hole? Reason being, all the weight on the middle axle and much less weight on front & rear axles allowing them to spin easily, stealing all the power leaving the middle axle with no power.
This B50 has a 2x25 Sabertooth in it b/c it was pulling a pup & I wanted separate power between the two axle groups for turning... now I've wired the middle axle to the 2nd motor driver and the front & rear axles on the 1st motor driver. The DIP switch on Sabertooth left in Independant Drive, radio mixed the two Sabertooth channels... problem solved! It'll likely walk up the long dirt ramp out of the basement better than it ever did before too.
