Old 04-14-2019, 08:45 AM
Member Number: 170
Default help! frsky qx7 sbus glitchy
hi gang, got small problem.
bought a qx7 to use with a tamiya semi, and 2 trailers, plan is to run 3 bound receivers a the same time to allow for operation of the truck and trailers simultaneously
saw this video on easy way to get 16 channels from youtuber steve smith:
got a frsky micro sbusreceiver from getfpv.com:
https://www.getfpv.com/frsky-xm-receiver.html
and 16 channel sbus decoder from banggood :
https://www.banggood.com/16CH-SBUS-t...r_warehouse=CN
using sg90 micro servos:
https://www.banggood.com/TowerPro-SG...r_warehouse=CN
i've got everything hooked up and working with 1 servo, but when connect 2, the whole system goes glitchy and i can't control either servo. if i wait a second it settles down and i can run 1 servo again, but 2 servos give it fits.
what!! they're not??
Old 04-14-2019, 01:17 PM
I'm thinking either a bad servo or not enough current being supplied and causing a brown out.
How big of a BEC or RX Battery are you running on that? Either stand alone or through the esc?
Do all 3 of the rx setups do that, or just 1
Old 04-14-2019, 02:24 PM
Member Number: 170
just tested the one right now, still setting up radio. using 4 AA rx pack. thought it might not be enough, but i've run sail servos on 4 cells, so a micro servo with no load should be fine...
Old Yesterday, 06:10 PM
Wombii's Avatar
Wombii Wombii is offline
Styrene apprentice
Member Number: 5663
Have you tried measuring the supply voltage with a multimeter /voltmeter while the glitches are happening?
Styrene project: Scania Rosenbauer airport fire truck - http://www.scale4x4rc.org/forums/showthread.php?t=82630
