Old 01-06-2017, 10:08 AM
Default Hairba11's TF2 project
So I traded a Jugg for a tf2. It has a lexan yota-ish shell, and came with a new in box Mojave body set.
I used some Rustoleum apple red (from my f100 1:1), some flat black (from my f350 1:1 liftgate), and some dark brown (from my s10 1:1 interior)
And gave it some color after figuring out this yellow plastic wouldn't take dye.
Then since it had all the holes for lights already, I decided to go all out.
$5 on eBay got me 100 (5x20ea) red, blue, white, green, and yellow led's.
I already had resistors so away it went.
I got the front end detailed using some 5mm incandescent bulbs for the headlights and a little shoe goo and aluminum foil in the light buckets.
Yellows went in the bumper and front corner markers.
I swear this worked easier when I was thinking about it
That's a little neater
So these are a PITA to get in with the bulbs in place.
White for reverse, red for brake and running lights
I also illuminated the dash. Blue behind the gauges and hvac, and green behind the radio
I'm using an old dig switch setup for my reverse and brake lights. And since I already have one servo going in, I might as well have two. I used a m2x16 screw in the servo, and used 1/8" heat shrink tube to connect the wheel to the bolt head.
Old 01-06-2017, 05:08 PM
SFC K's Avatar
SFC K SFC K is offline
What is your zombie plan?
Member Number: 14349
I like this and that you are adding a working steering wheel!
Old 01-07-2017, 10:43 AM
Got some stuff wired up yesterday.
And naturally, I need a servo reversing Y for the steering, and the servo CA'd between the two micro switches is dead so I get to tear that apart.
Old 01-07-2017, 03:07 PM
Frederik Frederik is offline
Member Number: 20276
Love the color the incandescent headlights turned out. Where did you pick the bulbs from? I am also looking for less white than LED lights, but was thinking of painting white LEDs to get a more yellowish color.
Old 01-07-2017, 07:53 PM
eBay. Searched 5mm incandescent bulb. Got a 20 pack of 6v for $4-5. You can also order warm white led's. Aim for 2500K if you can find a color temp. 3500 is blue, 3000 is white.
Old 01-07-2017, 08:29 PM
Now that's very cool, thanks for the tip I am buying a set as soon as I can find one that is not 1.76$ and 26$ shipping lol! Probably because I live in Canada... I see another one with better shipping price but it is 12V instead of 6v.
Old 01-10-2017, 08:46 AM
Lightshttps://vimeo.com/198844908
Old 01-10-2017, 09:12 PM
nice job with the lights.
and I like the red paint.. looks good on that body. =)
Old Yesterday, 01:47 PM
Got the winch running off an old duratrax mini quake esc, got the light switches mounted under the bed. https://vimeo.com/199568241
Old Today, 05:21 AM
FREEDOM83's Avatar
FREEDOM83 FREEDOM83 is offline
-Football +Races
Member Number: 20423
OMG !! amazing light work !!
Old Today, 06:16 AM
The little extra's are fantastic.
Coming along great.
Old Today, 02:20 PM
Thanks guys. It is really ugly under the lid. And the battery in it currently is huge, I had to move wires out of the way to keep them from hitting the steering wheel.
I have a lot of work cut out to try and get an interior in and find places for everything.
Copyright 2004 - 2016, Scale 4x4 R/C
