Old 09-09-2011, 11:32 AM
Xporter Xporter is offline
Member Number: 13183
Looking good, keep it going!!
  #62
Old 09-10-2011, 12:15 PM
Paul4x4's Avatar
Paul4x4 Paul4x4 is offline
Monster truck enthusiast
Member Number: 15569
Today I bolted steering servos and the engine under plate to the chassis, and tomorrow I'm gonna try making some mounts for the throttle servo if I have time... Also had to order a new set of engine mounts, because I wasn't happy with the mounts i had.
Here's how it looks like with the body on it!
Old 09-12-2011, 07:15 AM
Paul4x4's Avatar
Cool
Yesterday I started making the throttle servo mounts, but then I found some small block engine mounts I had mistakenly ordered in the past, and those had exactly the same screw pattern as in the servo, so all I needed to do was four pieces of brake line to give some support for the screws. And the other mount was even hollow on the inside for some reason, so it was easy to run the servo lead through it after a slight dremel work. And there's even 1mm clearance left between the mount and the gear!
And I needed to bolt the axles to the chassis, because I had forgotten to take measurements of the drive shafts. After that it looked like this...
Then I had to go and see how it would look like outside!
I need to lower it a little bit in the future, and I think it will drop slightly on it's own when it has all the weight on it...
What do you think, does it resemble even remotely the real Digger or not?
Old 09-12-2011, 08:48 AM
lemecanodejante's Avatar
Scale is good!
Member Number: 1144
look really nice! a bit lower OK, AND you need to shorten the wheelbase too (or it's pics effect?!)
Old 09-12-2011, 09:05 AM
Paul4x4's Avatar
Thanks!
The wheelbase is measured from a picture of a real Digger that I printed to scale(actually the first pic on the first page), so it should be true to scale...
Old 09-12-2011, 08:01 PM
hairba11's Avatar
hairba11 hairba11 is offline
Rollin' in the winnie
Member Number: 4269
wheelbase looks dead on, chassis looks dead on, sticker graphics aren't too obvious, just look at this pic
that says it all, if it were parked in an field that hadn't been mown and was 3 feet tall. just need the ads on the sides in the center of the chassis and some headers coming out from under the body
link to full size
http://upload.wikimedia.org/wikipedi...ave_digger.JPG
granted it looks like you're copying a different chassis than this one but it gives the idea, i mean hes only had what, 18 of the things.
Old 09-13-2011, 12:45 AM
Banana's Avatar
Banana Banana is offline
Member Number: 9159
yeah, this really looks like the real Digger
I love it!
It onlu need side chassis plates like in Hairba11's photo than it will perfect
Old 09-13-2011, 01:10 AM
MojaveMonster's Avatar
a Dezert Speciez
Member Number: 3809
x2 on the side plates. Not to mention it would cover up the chain drive.
But either way it's an awesome build and I can't wait to see video one it.
Old 09-13-2011, 06:17 AM
Paul4x4's Avatar
Thanks guys!
And if you look at the pictures closely, you can see there's mounts in the chassis for the ad panels. I already have the stickers waiting, and today I picked up a sheet of polycarbonate, so all I need to do is cut those panels out of it and bolt them on the chassis!
After that I'm probably gonna start fabricating the sway bar arms...
Stay tuned!
Old 09-13-2011, 09:47 AM
Paul4x4's Avatar
And now that I figured out how to link youtube vids, here are a couple clips of the Digger.
Old 09-14-2011, 11:41 AM
Paul4x4's Avatar
And here is what the crowd's been asking for!
I made an ad panel to the other side of the chassis today.
Need to take some scale pics outside when the weather gets better...
Old 09-14-2011, 12:51 PM
Spoon37's Avatar
Spoon37 Spoon37 is offline
Member Number: 16
Looks great
don't often see this kind of detail on most peoples monster trucks, even those get labelled "replica" or "scale"
Old 09-15-2011, 06:25 AM
Banana's Avatar
Member Number: 9159
Originally Posted by Spoon37 View Post
Looks great
+1
can't wait to see it running...you may build a scale monster stadium track with 1:8 cars and buses to crash
Old 10-19-2011, 04:25 PM
black maxx's Avatar
black maxx black maxx is offline
Monster Trucker
Member Number: 15285
That is the closest thing to the real deal right there.That is so scale i had to have a double take to see if it was real or rc.
Old 10-19-2011, 05:04 PM
BADMUTHATrUCKER's Avatar
Varyag og Muspelheim
Member Number: 1018
B/S/T Feedback: (14)
*speachless*
