Old 05-14-2017, 06:41 AM
I was digging around searching for a car title yesterday and lo and behold..
I come across this and just had to giggle thinking bout your build ..
C-cab was such and awesome idea...
Hope it sparks some more Ideas...
  #77
Old 05-14-2017, 06:23 PM
hairba11's Avatar
hairba11 hairba11 is offline
Rollin' in the winnie
Member Number: 4269
Very nice! I bought a bunch of those style kits back in the day. Did them all gloss black and gold my 1995-2000 vision of what my hot rod would be
Old 05-15-2017, 02:15 PM
hairba11's Avatar
Member Number: 4269
Another small update. Got the wires extended for the power and signal on the ducted fan ESC and ties on some of the loose stuff
Also figured out maybe where the steering servo is going.
Old 05-16-2017, 06:00 AM
Ive been back a few times studding your models....
Seeing some crazy cool mods the more I look !!
Fun and awesome.
Just curious.. Do you guys have a pulling sled round your parts For the RC's ?
I can so visualize this chained up and running the line.
I can see this one also painted Black now with Gold ascents and lettering..Ahahahaaa.
Old 05-16-2017, 09:18 AM
hairba11's Avatar
Member Number: 4269
They're still a little banged up from moving from Missouri to Indiana to Indiana to Indiana to Missouri to Missouri, so 6 times in 15 years roughly. I just haven't taken the time to reassemble them.
More updates
I cut a hole in the floor
Then drilled a hole in the side, and shoe-gooed a servo in place
Exposed bell-crank steering.
Now to get a piece of 3mm music wire to make a 14" drag link so I can get rid of the joint in the middle.
Old 05-17-2017, 10:30 AM
hairba11's Avatar
Member Number: 4269
Made a seat and steering wheel. Working on shifter.
foam
o-ring and servo horn.
3.5" 8-32 bolt steering column.
Old 05-17-2017, 11:57 AM
Wow....loving the steering wheel idea! Awesome!
Old 05-18-2017, 02:50 PM
hairba11's Avatar
Member Number: 4269
My favorite way to do this. Practically free.
R26 O-ring and a four way servo horn and shoe goo.
Drilled out and slipped on a #8 size bolt, with one of the servo rubber mount bushings holding it in place.
Gives it the old model T style 4 spoke look.
Old 05-19-2017, 06:01 AM
Awesome build buddy! Is this the wrong forum section now??? lol
Old 05-19-2017, 06:25 AM
Hows the shifter coming along ?
Old 05-19-2017, 08:19 AM
hairba11's Avatar
Member Number: 4269
Default Hairball's T-bucket
I know, right? It's 4wd now...
it's in progress. I had another distraction. Cat got in a fight and has a dime size hole in her back
Old 05-19-2017, 09:44 AM
hairba11's Avatar
Member Number: 4269
Started out drilling two holes
Then drilled a bunch more
Then stuck the shifter through with a bent roller chain link welded in place
Looks like a shifter
The bale on the transmission will go into the front loop of the shift rod, and then I'll bend the loop closed. I was originally going to try for servo shift, but the gearing is going to be so low it's going to live in high.
Old 05-19-2017, 10:06 AM
Oh man...that's looking sweet!
Old 06-03-2017, 08:30 AM
hairba11's Avatar
Member Number: 4269
I'm still alive!
After a week of a stomach flu and getting caught up with work I hit the shop running.
Body is finally mounted!
Another driveline shot
My shifter is in and tweaked
Low gear
High gear
I finished getting everything wired up and got it hooked up to the radio
The steering steers! Kinda. It flexes a lot at the black plastic joint. I need some 3mm music wire to make my own rod with.
The ducted fan spins! The wrong direction but I have to take the whole thing apart to get to the motor wires to reverse the rotation. Reversing the transmitter just changes the direction of the throw, not the direction of the airplane esc.
The drill motor turns and the rig drives! About two inches before the chain walks off the sprockets.
And the rear tires really drag. I need some wider hexes I think.
But it looks great!
Old 06-03-2017, 10:59 AM
Holey crap dude! That is seriously badazz!! Awesome work!
