Old 04-23-2019, 09:41 PM
Sorry 4x4 I got "interrupted" by my adult responsibilities while I was cutting out my brakes this morning haha. I will post up pics of what I've got done as it may help illustrate the steps... I will get four rotors done tonight to the same finish as my first one in the above pictures. I need to hit up some hardware stores for a Dremmel router attachment. If I can't find one tomorrow I might hit up some local engraving company to slot my rotors. I'd do the groundwork layout- jig maybe?. I'd prefer to find the mini router attachment. I've had need for one in the past.... hold,... hold,....ho o o ld
  #287
Old 04-23-2019, 10:54 PM
Quick name that movie reference?.. Found some music from a certain soundtrack on the HDD in the Jeep and it was stuck in my head as I posted above. Okie dokie, some process shots;
Old 04-25-2019, 11:53 AM
My rotors I'm making are an interference fit. That is to say they are pressed on with no other type of attachment. Through trial and error I found just the right brand of hole saw in the size I needed to accomplish this. With my ramshackle "machining" method and controling my "out of control" methodology I could consistently get just the right size hole in aluminum test scraps. We're talking 2 thou of an inch under, maybe a bit more? This wiggle room for tolerance is made a little easier owing to the fact that there is a slight taper on the Tamiya hub and it is made from soft pot metal...
So how many attempts did it take me to make four rotors?...
FOUR.., but wait one of those was a prototype never intended to be used. OK so I had to make five. No problem -one more, I got this
Here is a picture how many I ended up having to make to have four that worked. By any strech the failed attempts fit like a glove, just not like an OJ simpson glove... No good In the pic above you can see what I mean by ramshackle. The kerf the hole saw makes is very wide. Luckily for me as long as everything was clamped, didn't bind, drilled quickly (no excessive spinning of the drill press beyond making the hole- imediate shut down) and lastly not allowing the still spinning hole saw to make a "second pass" through the material -as in raising the handle/ chuck before shutting down. Eveything worked out fine I don't know where or when but one measly tooth broke off the hole saw and after that producing an interference fit was interfering with my patience and perseverance. Well, I hope that explains my lack of progress but I got'r done eventually. Cursing my lack of shop full of machine tools in the process lol... Mark
Old 04-26-2019, 12:03 AM
4x4lover4499's Avatar
4x4lover4499 4x4lover4499 is offline
To many projects not enough time.
Member Number: 16060
Thus the reason I bought the rc4wd ones......
But I have to say your prseverance is impressive.
When in doubt, Throttle out!
Old 04-26-2019, 09:45 AM
Look'n good 4x4, with that lighting it looks like a 1:1 in somebody's garage at night time. love those hubs too...
Old 05-13-2019, 11:55 AM
spankrjs's Avatar
spankrjs spankrjs is offline
This Space for Rent
Member Number: 2108
B/S/T Feedback: (15)
Glad to see you are still working on this
Very slick work with the rear axle narrowing
Nothing like the smell of a new Tamiya in the morning......
Old 05-13-2019, 01:51 PM
Thanks Ray.... Need to update but have been de-winterizing our camper and doing some post winter Jeep maintenance
Old 05-14-2019, 05:07 AM
Prop Shaft's Avatar
Prop Shaft Prop Shaft is offline
What's a hypotenuse?
Member Number: 17246
Really is nice to see you back on this Mark. Im loving everything your doing.
I feel your photo bucket pains. A big part of why I haven't really posted in a while is because of what a headache it is to do so. I was using tapatalk on the ipad which seemed the most streamlined system I could find, but even then it was taking up alot of time, especially when posting to 3 or 4 sites lol. I still want to post some updates when I can find the time, but Iíll basically have to re-teach myself in the process. Maybe the impending warmer weather with get motivated!
Take care.
Oh, and uh... yeah.. Braveheart.
Old 05-14-2019, 04:12 PM
Bullitt's Avatar
Bullitt Bullitt is offline
Long Tall Texan
Member Number: 965
B/S/T Feedback: (8)
Take care.
I am right there with you. I have built 4 RCs in the last couple years and have not posted a thing. Photobucket knocked the wind out of my sail and I have not found a hosting site that works well in my mind. Photobucket didn't work well either, but I could work it better than the other sites.
The Bruiser is looking great and I have mine almost done. I am just waiting to pull the trigger on some decals and I can call it complete.
Harry
Old 05-15-2019, 11:50 AM
Hello Aaron how goes it? Thanks for the interest... I have a few more things on the chassis to get finished and then I will get to turn my attention to some styrene work. That should pick up the pace a bit. Ding Ding!.. Braveheart is correct sir you've won a dancing banana .
Howdy Harry, thanks. I'm eager to see your build... Glad you're still working on it!
Just a heads up guys I have been using Imgur and it is very easy to use. Very few steps to take for each upload. 4x4lover suggested it to me and I'd say it's easier/ faster than pb. Have been working on the 1:1 4x4, brought my frame down to bare metal (90%) and repainted. I'm all done now so back to the Bruiser after some camping this weekend.. I'll post some pics in the 1:1 section. Thanks for the interest guys, I appreciate it. Nice hearing from you!.... Mark
