Old 05-01-2019, 05:15 PM
They look great together! (Unimog, do you even lift?)
Is the first helmet pic a pink Ushanka or a brain-sucking alien. It came together nicely though.
  #107
Old 05-03-2019, 06:42 PM
Wombii's Avatar
Wombii Wombii is offline
Styrene apprentice
Member Number: 5663
Nice helmet. Thanks for showing me how I can do that if I make some firefighters.
Styrene project: Scania Rosenbauer airport fire truck - http://www.scale4x4rc.org/forums/showthread.php?t=82630
Old 05-04-2019, 12:17 PM
scaleraddict scaleraddict is offline
Member Number: 20917
Thanks guys
WOMBII, the first idea was to 3d print the helmet but I needed to ensure that the helmet was tight to the head and small, not looking like a mushroom.
Anyway, thought that the operator needed some goggles for his helmet. The first idea was to scratchbuild everything but my Dremel broke so I've copied the goggles' frame from the real army model and 3d printed it.The lens are from a bit of clear package plastic and the strap is a strip of bicycle inner tube
Old 05-04-2019, 07:23 PM
Very cool!
Old 05-05-2019, 09:03 AM
Small stuff: glueg the cushions for the seats
Old 05-06-2019, 05:00 PM
A friend gave me a scale CB radio from Shapeways for my Unimog. The thing is that I never mounted it and it sat for a while in the shelf. But the M548 it's also perfect for it. So, I've finished it.
The radio was painted black, including inside with nail laquer for the light don't bleed out(more on that later)
Need the mic so I did a quick one on PVC, the round part was achieved pressing a bearing against the pvc. The rest was dremel and sanding
Some thin cable wrapped around a wire could make a scale spiral cable?
I think so:
All assembled:
So, there's a LED behind and drilled 1mm holes on the front for the light pass through. In place:
Old 05-11-2019, 07:15 PM
more:
These LEDs were a PITA to mount. When I did the rear section,didn't thought in practicability to mount lights. But was doable:
It's a printed taillight with a real piece of stoplight inside
Headlights and winch:
And this:
You guys don't imagine for how long I'm waiting for that extra bit of patience to fit the weatherstripping in the windows and then, the wipers
first 3 are done
Old 05-12-2019, 04:05 AM
I love the details, well worth the effort in the end
Old 05-15-2019, 05:03 PM
Thanks!
M548 was nearly considered done, only needs the smoke generator fitted and paint the hull but there's something more important.the henglong gearboxes are not up to the task.
Working on new system using these gearboxes:
Ordered a 30:1 to test
Thought of machine the structure but 3d printing could do the job
Old 05-17-2019, 05:28 PM
First of all, I'll not say that this was my original creation
There's a german shop( https://www.modellspiegel.com/) who created and sells these gearboxes for 1/16 tanks:
I had several ideas for the new drivetrain and the chosen was heavily influenced by this layout above
But I the time, I'm not in condition of forking out all that money and also like to do things myself as much as possible
To the build,this is where it sits now:
Tomorrow will do a test trial to see if the ratio it's good or not, and then order the other gearbox
