Old 07-06-2010, 08:57 PM
oldskoolmini's Avatar
oldskoolmini oldskoolmini is offline
somebody call ghostbusters!!!!!
Member Number: 12168
Default oldskoolmini's 1/18 dodge 3500 prerunner (pic heavy)
okay so i'm fairly new to r/c vehicles and fabricating. But it hasn't stopped me from diving head first into my first scale r/c truck. the plan is to take a 1/18th scale jada toys dodge ram 3500 quad cab and turn it into a prerunner/ score baja racer. its a diecast body that is currently under the knife to shed weight. I am building an aluminum frame with 1/4" square tube to make a c-channel frame, then i will build a rollcage/bedcage out of 1/8" and 1/16" aluminum tube. i dont know how to braze but i will so learn. i also have my eyes on the 1/18 axle from rc4wd and will build the front suspension out of 1/18 duratrax vendetta parts and maybe fab up my own control arms. the wheels and tires will be rc4wd micro tires and wheels. i will post up the mock up pics when they are loaded onto my pc.
Old 07-07-2010, 12:50 AM
hare are some inspiration pics. pics tommorow of the build.
Old 07-07-2010, 03:05 PM
Snowman Snowman is offline
Member Number: 3847
watching this, always liked dodge prerunners
Old 07-08-2010, 07:08 PM
here are some pics of the diecast metal body i'm using. its under the knife to lose weight. the pics suck cuz my good camera died so im using my video camera to take the pics.
area where im gonna cut out the metal and add styrene flared fenders
area below the door. looked goofy with a "body kit" so it getting chopped off.
it came with a full show truck interior that will be replaced with race seats, roll cage, accessories.
yup it's got a hemi.
mockup with hummer tires that are the exact same size as the rc4wd micro tires. 1.90" outer diameter, 1.00" wheel diameter.
Old 07-09-2010, 09:47 AM
lemecanodejante's Avatar
lemecanodejante lemecanodejante is offline
Scale is good!
Member Number: 1144
B/S/T Feedback: (11)
cool project!
Old 07-11-2010, 09:38 PM
small update. the aluminum tubing i oredered came in yesterday. 1/4" square tube for the frame rails, 1/8" rod for the rollcage and some 1/16" rod for support peices to hold the rear fenders on and some other random stuff. also got a new propane torch and tubing bender. just waiting on my alumiweld rods from harbor freight. then i can start on the frame. what is a good way to bend up the raim rails? the bender i bought only does the round tube. do i just heat and bend the square tube to the desired shape? photos of the bending process would be very helpful thanks.
Old 07-11-2010, 09:43 PM
Waterboy's Avatar
Waterboy Waterboy is offline
I think I suffer from something.
Member Number: 10658
B/S/T Feedback: (9)
this is a cool project! For your question all i can say is
W@T3R8oY wUz H3R3! Well, im Broke MoFo #89!! Eat that Lauer!!
Im suffering from RC addiction. Oh it hurts so good.
Old 07-16-2010, 01:19 PM
scalersince08's Avatar
scalersince08 scalersince08 is offline
mid level fab man
Member Number: 9697
im watching this one now looks like she should be a good one
Old 07-16-2010, 02:53 PM
MojaveMonster's Avatar
MojaveMonster MojaveMonster is offline
a Dezert Speciez
Member Number: 3809
Stick the frame rails in a vise, heat, and bend. I wouldn't bend the same spot too drastically since you're using alumi. Bend it some then move it and bend a little more to keep from fatiguing the same area. Also I hear people fill it with sand to eliminate kinking of the square stock.
Also if you haven't worked with alumi brazing I would practice on some scrap first. Alumi reacts differently than steel or other metals. I've also hared you should bake the item first to evenly heat the metal so it doesn't crack when it cools. Cool it slowly. Hope that helps
So many projects to finish before Dec 2012.
Old 07-16-2010, 05:40 PM
thanks MojaveMonster! i'll look into that. the square stock im using has a thin wall. i have also seen some people pie cut the frame where a bend needs to be then braze the bend.
No real updates to post other than i have drawn out what the frame will look like and how i want to build the cage. I am having trouble trying to a small enough tranny to fit. also how do I lengthen losi mrc drive shafts?
Old 07-19-2010, 04:42 PM
okay small update time. i have started drawing out the frame rails and roll cage. ignore the green sharpie. it was all i had on hand to highlight the frame rails. On to the pics!
the upper c-arms will be redesigned to fit aruong the shocks i have planned. now i just need to order some alumiweld rods and some more dremel cut off disks and i'll be set. stay tuned!
Old 07-24-2010, 02:21 PM
crcoppens's Avatar
crcoppens crcoppens is offline
It wasn't me.
Member Number: 1736
This looks like a great project, really out of the box. I am interested to see the chassis come together.
Old 07-24-2010, 02:25 PM
Waterboy's Avatar
B/S/T Feedback: (9)
Wow, thats a nice rollcage and chassis man! Looking forward to seeing this, it should be really cool. i dont think you can lengthen the plastic mrc driveshafts, so i would buy so larger ones. if they are metal then there is a way to extend them. Im not sure what a mrc has though as ive never owned one.
Old 07-25-2010, 01:09 AM
vwmicrosizer's Avatar
vwmicrosizer vwmicrosizer is offline
driving mini z's
Member Number: 9660
great job oldskoolmini. mini as in the older mini coopers?
when I said i'd hit that I men't with my car
what about a drifting winnebago?
Old 07-25-2010, 01:14 AM
mini as in an old 79 toyota hilux minitruck i had. next check im gonna order some brazing rods and start fabbing the frame and cage. fabbing up some control arms still has me stumped. and I will be building a 1/18 diecast 2003 f150 for a friend soon too. his will be a crawler. ive thought about doing a metal mulisha style paint job on it. gotta bust out the airbrush after the body mods. just wait and see what i do for the front fenders.
