Old 03-29-2018, 01:42 PM
Dédé's Avatar
Dédé Dédé is offline
Member Number: 20697
Default Pinzgauer 712k orlandoo
as you may have noticed, I have a fairly simple motivation
that's why it's easy to make things complicated
it does not work all the time but hey ...
already, do the bodywork *
The crawler Scale,
it spent several hours fabricated something and 30 seconds to destroy everything
Old 03-29-2018, 01:45 PM
igotit's Avatar
igotit igotit is offline
I've been here so long my banana's turned purple!
Member Number: 3180
B/S/T Feedback: (29)
great start.....the random face pictures are a nice touch
im gonna fill their tires with diarhea....and litter the street with tacks.kick back and enjoy the show....that will show em!
Old 03-29-2018, 02:10 PM
Dédé's Avatar
the specifications are very simple *
the first condition of project was the middle bridge
Ugh, so simple, easier to do than with Axial :: D:
No, in fact the problem is always the same with a Pinz
it's wheelbase from a traditional 4x4
how to insert a bridge between the transmission and the rear axle
No, I assure you it's not the m *** e mounted, it's just meticulous
the doc is very clear and your screw enough to lose in the apartment: lol:
that is done
here, the trans is in place, so it remains the most complicated
Gimbals and there, will be sport
to make a truck like 6x6 nothing easier
it's like an Axial, you add the bridge 3 behind
I think I managed 2 flexible gimbals
but I dare not test
it starts to take an interesting turn
The game, now, is to put everything in: bhey:
Once is not custom
I bought a carro in ABS
do all the details at 1/35,
The gimbals are in place, 2 of 20 mm and one of 11 mm
one is to resume transmission output
Rear axles on rocker
Presentation of the bodywork
these are the main lines but there is still a lot of work on the hunt
The crawler Scale,
Old 03-29-2018, 02:16 PM
Dédé's Avatar
the work of the day
bindage branching and other, the electro is good: boo:
and for the 3 rd time, I took the front end after advancing the 10 mm trans and lowered by 5 mm
Links lower 24 mm, upper links 14 mm and cardan 20 mm
Bridge 2
22 mm and 11 mm links, 20 mm gimbal
The crawler Scale,
Copyright ©2004 - 2018, Scale 4x4 R/C
