Old 09-15-2017, 11:54 AM
potatocat's Avatar
potatocat potatocat is offline
Large, slow cat
Member Number: 17127
Default Source for mini rod ends?
Hi all,
I am about to start a micro-sized project, but one thing is missing.
I don't have a good source for tiny M2 or 2-56 sized rod ends.
I would prefer a proper through-hole rod end, and not ball-screws with press-on ends.
I am making suspension and steering links with them.
Any suggestions would be appreciated.
Thanks!
Old 09-17-2017, 01:51 PM
thatguy's Avatar
thatguy thatguy is offline
Member Number: 898
http://www.aliexpress.com/item/10PCS...02.4.32.Uwy9dF
Coming to you from crown an pepsi land. Everybody knows thatguy
Old 09-18-2017, 08:37 AM
bigscalebri's Avatar
bigscalebri bigscalebri is offline
Formally known as BigRigBri
Member Number: 21500
I have had the same trouble with sourcing some for the 1/24 losi buggy hybrid build I'm doing.
After much research I found the Align trex 250 model heli to have tiny balls and click on link ends with the balls at around 3.5mm dia and these fit sweet on the wheels end with no rubbing but I ain't had time to complete the rods.
Old 09-19-2017, 10:56 AM
A quick pic.
https://i.imgur.com/trdHzER.jpg
Old 09-22-2017, 07:58 AM
potatocat's Avatar
Large, slow cat
Thank you! I ended up ordering up a whole bunch of these:
https://m.aliexpress.com/s/item/32762637187.html?spm=a2g0n.orderList.0.0.51fe6a3fF UG07J&
3.85USD for a bag of 10. The project I am using these for needs about 48 rod ends. The duty cycle and loads are light so they should hold up. I also got a few vintage Kyosho and the Trex 250s for backup.
