Go Back   Scale 4x4 R/C Forums > In General > Scale 4x4 R/C Official Regional Clubs > London Scale Trail Runners
Old 01-08-2017, 04:27 AM
Fourth Protocol's Avatar
Fourth Protocol Fourth Protocol is offline
Keep calm and rage quit
Member Number: 23725
Im in, class 1, and whatever the class is for a 6x6.
Old 01-13-2017, 02:08 PM
Pete Stratford Pete Stratford is offline
Member Number: 23301
class 1 & 3 please
Old 01-15-2017, 12:44 PM
Breakingstuff Breakingstuff is offline
Member Number: 24219
I've got a stock ascender (blazer) with the floating battery is it legal to run? And what class would it be in?
Old 01-15-2017, 02:52 PM
It's definitely legal. Tyre size (if I'm not mistaken) will make it a class 2.
Old 01-16-2017, 03:26 AM
4WheelRC's Avatar
4WheelRC 4WheelRC is offline
Scale truck obsessive.
Member Number: 21252
By "floating battery" I'm assuming you mean the way the stock ascender has the front of the battery tray connected to the front axle? If so, then its not strictly SORRCA legal:
Ref. http://www.scale4x4rc.org/forums/showthread.php?t=76348
Batteries must be chassis mounted and should be hidden from view.
And ref. http://www.rccrawler.com/forum/scale...ml#post5118580
WP gave you the explanation, "It's not so much that the Ascender battery mount makes it an awesome performer, it's just that others will exploit that rule if they can use it to make their rigs perform better." That is why it is not legal, not to mention, the rule was determined way before Vaterra came out with the Ascender.
When the Ascender came out, the battery mount caused quite a stir and AFAIK it has been left that you need to unlink the battery tray's connection to the front axle.
... all that said, I'm not sure us folks at LSTR are bovered?
Old 01-18-2017, 03:53 PM
Dready's Avatar
Dready Dready is offline
Bucket List 1) Get a Truck on American TV. Completed
Member Number: 2380
B/S/T Feedback: (18)
I was under the impression you had to change it if you wanted your score to be counted. If your not bothered about points then leave it as is.
Old 01-19-2017, 04:37 AM
I stand corrected Guessing this is the relevant rule:
No "Motor On Axle" (MOA) of any kind. All motors, transmissions, and other electronics (other than steering servos) must be chassis or frame mounted. Your axles must be driven by one transmission or transfer case and a minimum of two drive shafts (except CC-01, TA-02, etc) No separate throttle control of drive shafts or axles.
Old 01-19-2017, 12:08 PM
Dready's Avatar
Member Number: 2380
Yes
Old 01-21-2017, 01:07 PM
willkrawl's Avatar
willkrawl willkrawl is offline
Scale the world realism we share
Member Number: 12110
All scoring be it scale points or course points are done on trust, as this is your first meet (I am guessing )I don't think the guys would mind unless you win your class ,easiest way is just cable tie it to chassis.
Class wise on stock tyres I've been asked this before (as can't find spec on them),and measured at 106 ,so class1
Old 01-22-2017, 06:23 AM
JBL JBL is offline
Jay B. London /Surrey
Member Number: 24989
Question
Please count me in probably class 1.2.3.
Just 3 questions please:
- Will I stand any chances to complete all courses without winch (curently non working on my cars).
- Are you guys changing width of gates for class 2, or just class 3 gets widened?
- Can be 6x6 with CMS in any class (by tyre size)?
Thanks in advance, Jay
Old 01-22-2017, 07:02 AM
willkrawl's Avatar
The courses will set out that you shouldn't need to use a winch but that don't include driver error or the courses changing throughout the day (weather or getting cut up etc).and ofcouse there is a 3point penalty for using a winch.
Gates are only widened for class 3
Yes but most run in class 3 due to vehicle size
Old 01-22-2017, 10:30 AM
JBL JBL is offline
Thank you for advice, all clear
... the width of my vehicles is worrying though.
That would put most of my vehicles in C3:
- upgraded HG 6x6 is too long to turn through narrow gates
- SCX10 with optional 4WS on 125mm tires and is 10inch wide
- just built Vaterra TH
and only one other standard SCX10 left for C1
As tere is never much time left for C3 at the end of day, Ill have to make some tough choices
Old 01-22-2017, 10:39 AM
JBL JBL is offline
PS:
... I suppose that each driver is only allowed one car per class to enter comp,
right?
Old 01-22-2017, 01:12 PM
willkrawl's Avatar
PS:
right?
Yes that's right and you must use a different vehicle for each class.
Old 01-23-2017, 10:50 AM
Mudsweatandtears Mudsweatandtears is offline
Member Number: 25167
I'll try and come. It'll be my first and I'm not sure on which class I'd be. Stock trailfinder running multi link suspension?. Be nice to meet you all :-)
