Old 01-09-2010, 01:57 AM
mohamax's Avatar
mohamax mohamax is offline
Member Number: 9849
Default how to wire a 3 racing winch - DX6i
Hi guys
Please help....
How do i wire up or connect my 3 racing winch to my receiver.
I have a DX6i 6 Channel, the winch has 2 wires, as soon as i connect it - the winch starts to spool in.
The winch is fitted to a high lift - using 3 channels of the 6.....
diagrams welcome.....
Old 01-09-2010, 02:18 AM
Jaskafin's Avatar
Jaskafin Jaskafin is offline
Member Number: 1466
Originally Posted by mohamax View Post
Hi guys
Please help....
Have you got the winch controller on it because you wrote that you have 2 wires,probably red and black.If this is correct you are missing the winch esc what drives the winch
I had problem on it..Winch controller was broken. Black button is for
Have tried to stop winching with that small black button was is in the winch controller.I have 3 position switch for winch use on Futaba F-14s.
Here is 3racing homepage for more info http://www.3racing.hk/articles.php?articles_key=28
Old 01-09-2010, 03:01 AM
MATT01234 MATT01234 is offline
17INCHES OF.....................
Member Number: 6397
Have you set the trim right?
Old 01-09-2010, 04:27 AM
You need to connect the winch to a speed control. It's just another motor.
Old 01-13-2010, 12:19 AM
mohamax's Avatar
Member Number: 9849
Hi guys
Thanks for the help....
I dont have the winch controller, just the red and black wire.
is there another way to wire it up?
Old 01-13-2010, 01:29 AM
sloppy's Avatar
sloppy sloppy is offline
Member Number: 863
sure hook it to a small cheap forward/reverse ESC.. you should be able to find a few Plane style ESC's that have forward/reverse 5-10 amp range should be plenty.. or you can gut a old ESC and use the board from that..
http://nostr.net/forums/
Old 01-13-2010, 05:08 AM
denty's Avatar
denty denty is offline
LINCS RC OFFROAD
Member Number: 5457
where did you get the winch from without the controller? im just about to put a second motor onto my winch to pull my heavy challenge truck and going to use an esc to control it.
Old 01-13-2010, 05:13 AM
You could gut an old servo and use the board as a speed control.
Old 01-13-2010, 02:51 PM
The Stray Cat's Avatar
Everybody Needs Rock N Roll
Member Number: 4514
B/S/T Feedback: (45)
You can order the winches with out the controller. I hooked my winch up using a $3 radio switch. It can't be done via remote but, I'm going to need to be close to the truck when winching anyway.
Old 01-28-2010, 09:46 AM
c00kie c00kie is offline
Member Number: 10593
Hi,
New to this hobby and building an SCX10.
I bought the 3 racing winch complete with the controller. When I connect it up to a battery and control it with the button it is fine i.e. 1 press to spool out, press again to stop, press again to spool in and so on.
I've connected it up to my reciever 3rd channel (I'm using a Spektrum DX3S) and the winch is either spooling in or spooling out - how do I switch it off from the transmitter?
The Spektrum transmitter has a tiny button for AUX control which is either up or down... I tried adjusting the Travel Option on the AUX channel so that H was set to 100% and L was 0. This means I can flick the AUX switch up to winch in and down to stop, but then I can't spool out :-(
I'm assuming I'm missing something obvious (as usual!)
Any guidance much appreciated,
Mark
Old 01-28-2010, 10:58 AM
reddevildemo's Avatar
Member Number: 3586
B/S/T Feedback: (9)
Will not work on a DX3s as that is a 2 position switch. It needs to be a 3 position switch to work.
With the S it will either be off or in/Off or out. A (DX3R) 3 postion gets you in, off, out.
"There is no better friend...
Old 01-28-2010, 11:31 AM
It doesn't matter how much research I do I always end up getting the wrong thing
I think I will have to resort to some PIC programming and make my own winch interface so I can use a simple code to control it. E.g. hold AUX on to winch in, flick on, off and then hold on to spool out. Maybe I can add some lighting control too . An opportunity to merge two hobbies...
Cheers,
Mark
Old 01-30-2010, 07:15 PM
Waterboy's Avatar
Waterboy Waterboy is offline
Member Number: 10658
B/S/T Feedback: (9)
way to keep your head up bud hey, i was gonna buy that, but thanks to YOU im not gonna get it!fewf
Old 06-08-2010, 08:31 PM
Aaronb Aaronb is offline
Member Number: 7420
another winch question. i have mine hooked up with the control and wired in to a seperate battery. for some reason it only spools in. i am running it with a dx3e. when switching down on the 3rd channel it will spool in, then i have to click up twice to get it to stop. it should stop in the neutral position (center) and spool out on the up switch? right? what am i doing wrong?
Old 06-09-2010, 12:02 AM
Espeefan's Avatar
Espeefan Espeefan is offline
Faster you fool!
Member Number: 311
I would think something is wrong with your sub-trim, or end point settings on the radio, if you can't get the winch to work with a 3 position switch on your radio. Center should be neutral, or stop. Either way the opposite directions should be in and out. Try hooking a servo to the channel and monitor what the servo does. It should center itself in the middle position and move to the extremes in the other positions. If it doesn't, you have some EPA, trim, or sub-trim dialed into that channel.
Ideas without actions never become bigger than the brain cells they occupy.
