Go Back   Scale 4x4 R/C Forums > Monsters, Scale 4X2, & Non scale R/C > Rock Crawlers
Rock Crawlers For those Rock crawling, stone sliding, body scratching, articulation crackheads; this place is for you!
Old 03-25-2016, 07:12 AM
rush2112guy rush2112guy is offline
Member Number: 24087
Default Warn Winch tightening on its own
I have the Warn 9.5cti 1/10 scale winch and it seems to be tightening on its own, very slowly almost creeping. Anyone else have this issue and how did you fix the problem?
Thanks for you help
Old 03-28-2016, 10:17 PM
IronSavage IronSavage is offline
Member Number: 5350
I don't own a warn 9.5 so i can't help you. I'm just posting to say Hi. So Hi. and Roll that beautiful bean footage.
Old 04-17-2016, 12:34 AM
LAV25's Avatar
LAV25 LAV25 is offline
Member Number: 2743
I don't have a Warn, I've got one of the older RC4WD Bulldog winches, but I had the same problem, except mine was letting out. I got a "no drift winch controller" from Heyok, who I think is a member here, and haven't had any problems since.
The only difference when you use it is that your winch becomes toggled, so it's either letting out, static, or pulling in, there's no more proportionality, but I think that's how real winches work, so it shouldn't be a problem.
https://www.freewebstore.org/HeyOK-P..._15354761.aspx
-val
Yeah, I'm the guy you saw hammering in screws with a pipe wrench, why do you ask?
