Go Back   Scale 4x4 R/C Forums > Monsters, Scale 4X2, & Non scale R/C > Rock Crawlers
Rock Crawlers For those Rock crawling, stone sliding, body scratching, articulation crackheads; this place is for you!
Old 02-04-2015, 02:19 PM
iblis iblis is offline
Member Number: 9514
Default broken ESC I guess
I have a broken ESC (more likely) or brushless sensor motor.
I just had it back from store yesterday. and it is defunct again.
the motor is not turning at all. but at shop & before I put it back into the unimog, it's running.
any idea how to fix it?
it's Chinese brand skyrc.
I m pretty sure the rx and tx is working properly since I have tried on my trf 419
I did a calibration several times already.
Old 02-05-2015, 12:19 AM
Member Number: 9514
I just unscrew and open the motor and put it back. it's running now.
however, I can't tighten up the screw
no idea. the wiring is probably wrong. but i don't know how to fix it. it has to be reverse the throttle to make it working
Old 02-05-2015, 03:17 AM
Member Number: 9514
no idea what going wrong.
the motor is dead after running 2-3sec.
after switch off and on the esc, the motor goes live again.
Old 03-03-2016, 06:59 PM
dgonslayer's Avatar
dgonslayer dgonslayer is offline
Member Number: 13630
just seen this topic are u talking bout the 120 amp unit if so i have one an its been great if the motor screws are to long use cople washers or cut them bit shorter on the deal where it stops working check the plugs on esc that run to motor i had to clip the ends an re tin the wires guess they used crappy solder also u can use the hobbywing programer on it
Old 04-20-2017, 01:28 PM
owlsarepretty103 owlsarepretty103 is offline
Member Number: 25446
I thank you for the information! I was looking for and could not find. You helped me!
myhr cvs
