Old 06-16-2018, 11:14 AM
Originally Posted by Trini2DBone View Post
Ahhhhhh...so that's how you go about getting them curves! So you use the lines as a guide where to place the heat and where to bend?
Originally Posted by Noobsk8r View Post
Iím also very interested in how you do these radius bends so well
Hi guys..
Correct on the lines..
I keep the heat concentrated on the center lines, The outer C's
You let the material flex by it's self once it hits it's magic temp...don't try and bend it or you get wobbles.
It will droop by it's self.
Also....
Proportions are looking correct to my eye's.Started shaping cowl too.
Will try and vacuum form it as a single piece....I hope.. gulp...
Old 06-16-2018, 12:08 PM
Wow! That was fast Ron. I can only imagine how difficult it will be to tackle the compound curves of the cowl.
I am in the process of building a vacuum former and have a couple questions. Do you use any type of release agent? Would pine wood work for a buck? Any words of wisdom, will be helpful.
Old 06-16-2018, 12:29 PM
Thanks Willez
No on release agents.
The mdf I use.... if properly sanded smooth... releases easily Ö
as long as you don't trap yourself in the pull of it.
I did use Cooking PAM once on some bucks.. Worked the same as if I hadnt.
As for the Pine. Yes it should work good.
Be sure its super flat and no grain is sticking up.
I think it will be porus enough for air to flow threw it..
MDF is to a point. Any thing over 3/4 inch startst really restricting it though.
Luck on your ventures my friend, hope this helps.
Old 06-16-2018, 12:37 PM
looking very good
Old 06-16-2018, 05:38 PM
Rolex's Avatar
Rolex Rolex is offline
Young Street Urchin
Member Number: 23755
For someone who's out of practice, I can't believe you started with the grill, the toughest part.
As usual, this will be a real beauty. Looking forward to the progress.
Old 06-18-2018, 06:52 PM
Bullitt's Avatar
Bullitt Bullitt is offline
Long Tall Texan
Member Number: 965
B/S/T Feedback: (8)
Glad to see you back amigo! A green willys is always great! I will be watching for sure!
Harry
Old 06-19-2018, 05:57 AM
Huge thanks guys.
Vacation coming up..Bit slow right now on updates..
But when I sit down finally ...hang on to your chairs.
I'll pump out 20 pages of pictures...ahahhaaaaa
Build me a truck in just a few days....
I will be doing a few more bucks and vacuum form hood and roof too.
Getting a plan and some direction.
More soon just bare with.
Thanks again everyone.
Copyright ©2004 - 2018, Scale 4x4 R/C
