Go Back   Scale 4x4 R/C Forums > Monsters, Scale 4X2, & Non scale R/C > Monsters of R/C
Monsters of R/C If its massive, ain't scale, and can break an ankle when it hits you, put it here!
Old 01-28-2014, 06:52 PM
Arcocustom's Avatar
Arcocustom Arcocustom is offline
Three .001 on every moving part.
Member Number: 2344
1/28/2014 continued from posts 14 & 15.
Old 01-28-2014, 06:56 PM
Arcocustom's Avatar
Member Number: 2344
1/28/2014 continued from posts 14, 15 & 16.
Modified Tamiya King Cab wheels were drilled to fit over RCP Crawlers TLT-1 CVD's.
HPI #6125 Super Star Washer Set drilled to fit over CVD axle.
Old 01-28-2014, 06:58 PM
Arcocustom's Avatar
Member Number: 2344
1/28/2014 continued from posts 14, 15, 16 &17
Old 01-28-2014, 07:04 PM
Arcocustom's Avatar
Member Number: 2344
1/28/2014 from posts 14, 15, 16, 17 & 18.
Decided to move the upper shock mount location and make it's position adjustable.
Used an old Associated fiberglass shock tower as a template and drilled some new shock mounting locations.
FRONT
REAR
Thanks for taking a look. - Arco
Old 07-27-2018, 10:58 AM
Arcocustom's Avatar
Member Number: 2344
TAMIYA TLT-1
w/ NOVAK SUPER ROOSTER
Hand wound 8 Turn Single, Checkpoint based Putnam Propulsion motor
Trinity EX-TECH Triple Matched 2000mah SANYO Ni-Cd 8 cell saddle battery pack
Old 07-28-2018, 01:16 PM
Arcocustom's Avatar
Member Number: 2344
"Head for the hills"
- Kicking up dirt and flying off jumps this equipped R/C Racing Truck will
satisfy even the wildest off road driving enthusiast.
- Unstoppable Suspension... CVA Oil dampers, triangulated four-link and elongated alloy suspension arms all serve to heighten off-road performance. 151mmmm diameter tires are adopted for sure-footed traction on even the roughest of surfaces.
Customized Tamiya TLT-1 "mega-truck" 4x4 with a selectable rear differential locker.
(Tamiya)
  • #47201
    RC TLT-1 Rock Buster
    1/18 Scale Little Gear Series
    *#9404449 Chassis (L & R)
(Vertigo Performance Products)
  • Tamiya TLT-1 Rock Buster "Center Tranny Hub Locker"
    * allows use of Traxxas part #1951 "Half Shafts"
(ESP Racing)
  • #ESP060 Tamiya FORD F-350 Juggernaut "4-link Suspension Kit"
    * Custom made per my own specs by ESP
    * MAD TLT's new wheelbase is 11 & 7/8" (301.625mm)
(RC4WD)
  • #X-0005 Straight Axle Adapter for Tamiya TLT-1 Axle
  • #Z-S0407 RC4WD 12mm Mini Hex Wheel Widener Set (+15mm)
  • #Z-T0129 Mud Basher 2.2" Scale Tractor Tires
  • #Z-S0075 King Kong Mini Tow Shackle
Hop-Up Options for the TLT -1 Rock Buster
#51000 RC Hi-torque Servo Saver Set
#53021 3mm Aluminum Nut
#53022 3mm Aluminum Lock Nut
#53132 RC Fluorescent Antenna Pipe Set
#53444 RC Silicone Damper Oil Medium (#500, #600, & #700)
#53692 RC TLT Ball Bearing Set
#53777 RC TLT-1 Alum Gear Case Set
Hop-Up Options for TA03
#53286 Aluminum Pulley (16T)
Hop-Up Options for TA04
#53426 TA04 Racing Body Mount
#53452 RC TA04 Alum Hub for Spur Gear
#53573 Aluminum Touring Car Wheel Spacer (Blue)
#53579 TA04 Hard Front Upright
Hop-Up Options for TRF416
#42164 TRF sticker sheet
#54207 TRF416X Low Friction Belt (Rear)
TXT-1 Parts
#0224011 RC U Parts: 58280 (shock bodies)
#8085084 RC Body: 58280 (Clear)
#9415811 Damper Oil Bag (ML3 Rubber Tubing)
#9805804 *1 Coil Springs (MS4 x2)
#9805811 * Piston Rod (MG5 x2)
FORD F-350 High-Lift parts
#3455976 Propeller Joint High Lift Ford F-350 High-Lift
#9808085 Ring Gear High Lift FordF-350
Super Blackfoot
#9335116 Wheel Bag (Front x2 Rear x2)
Twin Detonator
#0440024 *1 Wheels (L & R, 1 pc. each)
TG10
#50808 Rear Wheel Axle (2 pcs.)
Mad Bison
#9494033 Sticker (a & b)
Old 08-30-2018, 10:04 AM
cartronicshn's Avatar
cartronicshn cartronicshn is offline
Honduras....rock heaven
Member Number: 1222
Wow, really nice , i still have a tlt based truck, i has 8 of them at one point, how are the pinions holding up? did you just change the ring gear?
Too many toys...so little time.
