Go Back   Scale 4x4 R/C Forums > In General > Pigpen of Miscellany
Pigpen of Miscellany This is the place to discuss anything you like that does not deal with R/C.
Old 01-21-2017, 08:47 PM
igotit's Avatar
igotit igotit is offline
I've been here so long my banana's turned purple!
Member Number: 3180
B/S/T Feedback: (29)
Gettin there
im gonna fill their tires with diarhea....and litter the street with tacks.kick back and enjoy the show....that will show em!
  #482
Old 01-21-2017, 10:29 PM
igotit's Avatar
Member Number: 3180
And the test
Levers have alotta of resistance,i could always make longer ones.
Just apply steady pressure and it all moves just fine.
Old 01-22-2017, 12:41 AM
SomeTexan SomeTexan is offline
Member Number: 23185
That's cool. Looks like you know how to keep the kids entertained.
Old 01-22-2017, 12:53 AM
igotit's Avatar
Member Number: 3180
Also keeping myself entertained
Lmao
Old 01-24-2017, 05:04 AM
Ahaha..
Sweet, I'm jealous here.
Pretty cool in my book.
Air gun topic again.
I went ahead with the titan Benjamin.22
Very pleased with the set up
Already amazing grouping at 21 yrds.
Going to order trigger mod.
Went with a simons scope too.
I'll try and get more specifics this coming weekend.
Old 01-24-2017, 05:16 AM
ou812 ou812 is offline
FlatBrokeCustomz
Member Number: 2317
B/S/T Feedback: (11)
With a .22 id go with a mil dot scope because of the flight trajectory.A mil dot in my opinion is the only way to go.
Welcome to the addiction.
Originally Posted by 2Beers View Post
Ahaha..
Originally Posted by talon View Post
i find myself somewhere between slightly aroused and highly confused on this one.
Old 01-24-2017, 06:20 AM
igotit's Avatar
Member Number: 3180
Titan is my favorite budget np ,just make sure its an airgun rated scope
Old 01-27-2017, 06:16 PM
igotit's Avatar
Member Number: 3180
Awhile back i posted up a truck i working on with a severly twisted frame,i finally got around to replacing the frame rails,crossmembers and countless suspension parts.
I finally got to install the body.
Still a long way to go.
We have 300 hours invested in this 2015 kw with 6800 miles that rolled over.
I left the cab,engine,trans in place,built custom stands to hold everything in place.changed out 1 frame rail at a time.
Paccor charges 38 hours per frame rail,a coworker and myself done both frame rails in 32 hours.
Its a first for me,hopefully the last.
Its a 480k truck when im done,we have around 300k invested.
1 mth ago i the truck went for its first test drive,once we knew she was good i installed the hydraulic system,blower,crane controls.
Its a massive project from start to finish.
Were currently making repairs to the damaged dump body.
Old 01-27-2017, 07:54 PM
sickcivic95's Avatar
sickcivic95 sickcivic95 is offline
Lost and confused on.... what was I saying?
Member Number: 6114
Man that's some twist if I've ever seen it. Looks like it was a "fun" job.
You can't keep a good douche bag down It's a douche world, we're all bagging in it- Quoted from thorsteenster
Old 01-27-2017, 08:23 PM
danielk's Avatar
danielk danielk is offline
I build Lowriders
Member Number: 1386
What a flex shot.
"When you do things right, people wont be sure you've done anything at all."
Old 01-27-2017, 09:30 PM
igotit's Avatar
Member Number: 3180
Driver was dumping dry powder drilling mud,had vibrator on and it wouldnt fall out,so he kept clutching out to rock it......this tank alone is 30k lbs,ground gave way and flipped over.
A very fun job,i personally replaced over 400 frame bolts 5/8 dia x 2-3 in long.
8 crossmembers,rear leaf packs,hangers,shackles.....each crossmember has 26 bolts to lock it in place.
I had to carefully set the outside width of the double channel frame to exactly 34 1/4 in outside width,while maintaining level frame rails from the cab to the rear.
Total frame length of 32 ft.
A time consuming task.
Out of 300 logged hours,i put in 212 hours alone.
It was a "go work on the red beast in your spare time" build.
Old 01-28-2017, 04:54 AM
Crazy crazy..
Wowzaa
Fully appreciate the time your into it.
Ive changed a cross member and cab before..
So much work.
You've done it justice my friend.
Mind boggling.
We had something really big going down at our local port yesterday.
Ive never seen so many State and DOT officers at one place and at one time.
Of course I got the inspection too.. But had a fantastic officer and I keep all my i's dotted and t's crossed , so things went smoothly and I was soon on my way.
They were even opening up the trailers checking cargo.
Pretty amazed to see that many massed and working though.
Old 01-28-2017, 09:52 AM
igotit's Avatar
Member Number: 3180
Thanx
The original build ticket from gap vax was 684 hours to install the equipment onto the truck.
I had to remove it,repair the truck and reinstall the equipment.
While i was there i improved on the mounting points of the equipment using factory frame holes .
Dot quiet around here,dont hear much from them......but im not a truck driver either.
Old 02-11-2017, 09:24 PM
igotit's Avatar
Member Number: 3180
Went fishing this morning
Black crappie (we call them sock-a-lait).10 inch average,and some palm size perch.
Old 02-19-2017, 01:49 PM
JoeThePro's Avatar
JoeThePro JoeThePro is offline
Member Number: 10576
Ha, that's hilarious. My coworker wrote the controls and display system for that vehicle (or a very similar gapvax model). I had a small part in it as well. Small world.
Sent from my Nexus 5X using Tapatalk
