Old 02-16-2017, 08:58 AM
I got the spool reversed in the rear
And got a tie rod and drag link in and did a quickie servo mount
And got it outside under power
Ok. It has a wild amount of dog track I need to get out of the rear, the servo sucks, I broke a lower front shock mount and lost both springs out of the front end(still need to figure out how to retain them) but it drives amazingly!
It's as good as I had hoped.
Old 02-16-2017, 12:19 PM
Knowing your skills, it will be up to speed in no time.
Looks fantastic out doing it's thing.
Really grabs my attention.
Digging on it for sure.
Old 02-17-2017, 09:53 AM
Still waiting on 'nese servos.
But I got some body panels made today
Old 02-17-2017, 08:19 PM
Frederik Frederik is offline
Member Number: 20276
Awesome machine! Very cool to see it in action on its wheels! The single link suspension seems to work very well. Nailing the vibe of the original pretty good to.
Old 02-18-2017, 11:59 AM
Junkyard Stance's Avatar
Junkyard Stance Junkyard Stance is offline
Junkyard Obsessive
Member Number: 24499
Hi Hairba11
Looking sweet ! - your metal work is superb, looks about as symmetrical as my eyes !
Keep up the great work !
N
Old 02-19-2017, 09:39 PM
Thanks guys. The feedback helps.
I used a couple of the round servo horns (disks?) to locate the top of the coil springs. It seems to work ok-ish. At least they don't fall out anymore.
Another buddy sent me o pic of an old O scale train set grain conveyor belt I'm going to try and make the fenders from.
Welding gets tricky when there is plastic really close.
Old 02-20-2017, 08:48 PM
Do you need the springs to unseat when flexing pr are they long enough to stay sit so you could attach them at both ends? Thinking or a small autobody sized sheetmetal piece cut to sit the springs and have like 2 or 4 tabs folded around the first coil so it retains it.
Old 02-22-2017, 09:37 AM
They're just about long enough to stay in. At full droop they dangle a little (currently attached at the top)
Got the front panels on today
I also discovered that the 1:1 is for sale. Naturally right after buying the wife a car.
