Old 09-15-2017, 11:14 PM
Lil Giants's Avatar
JOE
Member Number: 1683
Track trouble, 2mm pin shear on one side & good thing it happened b/c I discovered 2mm pin on other side slid out of place& was carving into gear case
Added 5" cheater boards to the cross dump today. Surprisingly stable, I thought it would wobble from being top heavy... maxxing out the 8wd power to ascend the dirt ramp, lead axle spinning while the other 3 are flexing sidewalls to the max, doesn't show up clearly in the vid.
  #1112
Old 09-28-2017, 02:43 PM
Lil Giants's Avatar
JOE
Member Number: 1683
Hauling out back of shop... sunny & 22, not many of these great days left before that ugly white stuff shows up again for 5 - 6months.
Old 02-20-2018, 03:01 AM
Lil Giants's Avatar
JOE
Member Number: 1683
Been working on a new B50 with a pup this winter. I went with brushed motors in this one, it'll run a little quicker than the old one with brushless.
The old B50 needed some attention a few weeks ago, had to pull the pump out to tighten the belt.
Old 02-20-2018, 03:07 AM
Lil Giants's Avatar
JOE
Member Number: 1683
Hauled a lot of dirt out of the basement last couple months
Used the ol GL to catch the lumps from the screener & pile in the opposite corner for the B50 to haul out later. The tunnel ramp is lil steep for the old GL, plus it only hauls half as much as the B50. Once the 'fines' pile upstairs got wide enough to use the bellydump again, parked the GL & hauled lumps direct with B50.
Last couple days been crushing dirt lumps & rocks
Monster pile of fines
Old 02-21-2018, 12:44 PM
350TacoZilla's Avatar
Member Number: 2402
Man I know I'm repeating myself here but it is always so cool to see what you've accomplished with RC power (when possible). I also love seeing the wear on the vehicles since they are being used as 1:1 stuff would be and the wear patterns look like they would on the fullsize stuff.
Old 02-22-2018, 05:49 PM
Lil Giants's Avatar
JOE
Member Number: 1683
Always welcome & appreciative of compliments 350tocazilla
Just about done with this adt & pup
I made a valve divider block from brass for the pup
This dump cyl was on the trk, right side... the flexible hose going to the "T" I think I made it a bit too short, box going up/down - changing angles tugging a bit on this fitting broke it loose from the tube. Pipe goes up to top of tube & broke loose from that soldered joint... buffed the paint off, resolder, repaint, put it on pup after dinner today.
Got the box on the pup, put oil to the cyls
This is where the connection is for the pup hyds
Got a leak, hoping I just over tightened the fitting & crushed the seal too much... put on a new fitting with some thread seal... give a couple hrs to set & try it again.
Made up some exhaust pipes from 5/16 Plastruct tube for this adt & the others
This air cleaner is 3D printed, used an 8mm magnet to hold it place for pictures & filming, leave it off during regular use so it don't get so dirty.
And I'm motivated to get busy putting this WA500 wheel loader together next, it's only 4yrs next month that I've had it ...been using it for spare parts on occasion for other models that needed repairs, still missing a couple parts that'll hopefully show up next month.
Degrease the cyls today & paint them yellow
Old 02-27-2018, 09:30 PM
Lil Giants's Avatar
JOE
Member Number: 1683
Got er done... well except for the decals & a couple of other bitty parts that'll show up in a few months.
Missing the fuel cap & fuel drain plug
Off to get the 1st load
Start painting the cab on the old B50 shortly... more than 50cy hauled in the last 3yrs
Trying to pull the steep grade with pup in tow, the rims on the tandem axle were slipping bad in the tires, I had to pull hard by hand to get the truck up the hill... I really hate gluing tires... not sure what this gasket maker goo will do, smeared it on today, see what it's like tomorrow.
Broomed off the ramp, nearly 5 gallon of clay powder/dust, very slippery. Road is wearing down bad!
Soaked the roadway with water, sprinkle on the fines, soaked it some more, rebuild the surface to make it smooth. Lay down some asphalt to protect the surface.
The fines pile grew a lot in the last week!
Old 02-28-2018, 10:13 PM
Lil Giants's Avatar
JOE
Member Number: 1683
A vid showing the 963 leveling the fines pile, had to reload the vid b/c the original kept pausing for reasons I do not know
Old 03-06-2018, 02:50 PM
Lil Giants's Avatar
JOE
Member Number: 1683
Quick vid of the 10wd pulling the grade
Presently working at cleaning up the last of the 'piled dirt lumps from the tunnel' from around the furnace.
Old 03-14-2018, 11:12 PM
Lil Giants's Avatar
JOE
Member Number: 1683
Tidied up the last of the lumps around the furnace
Piled it all in the opposite corner, easier to load out trucks to haul to the surface
Screened it all the last 5 days
Big pile of hard lumps & rocks to run through the crusher
Lots to haul out this summer
Old 03-18-2018, 03:23 PM
igotit's Avatar
igotit igotit is offline
Member Number: 3180
awesome progress....still impressive with every view of this thread.
Old 07-05-2018, 08:41 PM
Lil Giants's Avatar
JOE
Member Number: 1683
igotit
Corrected my track chain skipping on my Izzy dozer, a local machinist suggested increasing diameter of sprocket to change the pitch. Original sprocket diameter was about 1.985 inch, 1st try at 2.125" got me nearly half there, 2nd try oh so close at 2.23", it still skips occasionally with a blade full going uphill... close enough for now.
Been working on a 2nd cross dump the last month.
Put one way roller clutches on this trl to make sharp turns easier to navigate.
Put a 2x25 Sabertooth, AR8000 rx & a battery in 2nd trl, saves me about 20 feet of stringing wires to the tractor.
Monster piles of fines to haul out before winter... didn't measure the pile, but I'd guess there's about 10 cubes here to move.
On my 3rd load
Put it through trials for a week or two to see what needs to be modified/improved, then tear it down for paint. Takes a pretty wide corner; was thinking adding a 3rd trailer, but is probably too long for indoor travels.
Next build is a side dump trl for the 4206, hope to tip it with two or three Actuonix actuators, box dimensions will be the same as the belly dumps.
Old 07-07-2018, 10:42 AM
Lil Giants's Avatar
JOE
Member Number: 1683
Old 07-08-2018, 09:43 PM
Lil Giants's Avatar
JOE
Member Number: 1683
Hauled out about 20 loads Friday... then I had a couple hrs of trimming to do with the dozer, did the east side of shop just before darkthat night..
Smoothed out west side Saturday morning
Used the B50 & pup to fill in the holes along the wall on the west side.
Tonight I weighed out my cross dump train, the 1st try with plywood platform was doubled up & screwed together 3/8... not strong enough
Screwed a 3rd layer of 3/8... weight of platform is 38lbs
Loaded weight 219lbs (-38lbs)
Empty weight 137lbs (-38lbs)
Old 08-11-2018, 08:11 AM
Lil Giants's Avatar
JOE
Member Number: 1683
