Old 07-07-2011, 03:58 PM
IKke's Avatar
IKke IKke is offline
Oh hai!
Member Number: 5041
Hey Munster,
I'm asuming the body of your scaler is 160-165mm wide? It's gonna be hard to make some axles to fit under there. You might want to scratch build some with 1/16 differientals. Now where can you get cheap (durable) 1/16 diffs?
Also I really like how you used a drill to make a lathe
IKkeTech Waffle boards, steering Guards, scale wheel hubs, and more!
Check IKkeTech on facebook
  #242
Old 07-07-2011, 05:13 PM
UK_Andy's Avatar
UK_Andy UK_Andy is offline
www.mishacalvin.com
Member Number: 4544
What about fitting a ball diff? A lot smaller than a gear diff.
www.mishacalvin.com
Old 07-07-2011, 06:11 PM
MrMunster's Avatar
Member Number: 12649
No problem Padre, glad the pictures helped, I agree with "the point differential".
Building from scratch is all hard but worth it (I think)
Originally Posted by IKke View Post
Hey Munster,
Measuring across the same section as on the 1:1's the mini mine is 168mm, at the fender flares it is 180mm (the actual scale is 1/9.7th but close enough to say 1/10th )
Using a T-Rex 44 mini on the rear (158mm hex to hex) so should be close and diff housing is similar shape to my sailsbury, for the front I will narrow a yota axle..... And if you know of a suitable 1/16th diff....do tell
Thanks, drill seemed easier than by hand tho the side and rear fogs were by hand
Yep been looking for ball diffs will be easier when I get my mits on the yota axle, take it to LHS and rumage through their kits! (i know them well enough )
Old 07-23-2011, 11:33 AM
PeSousa's Avatar
PeSousa PeSousa is offline
Portuguese Guy
Member Number: 15049
Awesome work! Keep going man!
Old 07-25-2011, 07:20 AM
MrMunster's Avatar
Thanks man, don't worry......I won't stop
I'm getting a bit excited now!!! Got my stuff from RC4WD
Wheels, tyres and axles (the jar has the yota's internals in it )
Rears are on the axle, front is painted but not put together yet but you get the idea
Rear view to see the width on the axle
and now to get some work done........
Old 07-25-2011, 09:34 AM
fiat128 fiat128 is offline
Member Number: 11157
What an awesome build! I love the series land rovers... especially the ones that have the headlights on the wings like that. I have to say it though, and i'm sorry: The body looks soooo good, but the flares kinda look like they're made outta playdough. Maybe a bit more sanding would help them look better? I don't know. Anyway, I'll never build something like this so I'll just stop talking now. No harm meant. Wicked truck!
Old 07-25-2011, 10:18 AM
MrMunster's Avatar
Thanks for the compliment, as for the flares, I supose they do look a bit like playdough, but then so the ones on the 1:1
Old 07-25-2011, 03:41 PM
IKke's Avatar
Oh hai!
Member Number: 5041
The rear axle looks perfect. How are you planning on narrowing the yota?
Old 07-26-2011, 04:04 PM
MrMunster's Avatar
That rear axle is still a tiny bit to wide to be honest, about 3mm on each side even after I thined down the hexs, but it's close enough not to bother doing more work on it
As for the yota.....dunno yet, but I think it will involve a hacksaw and a file
This will be the first axle I've narrowed so I'm open to suggestions, if not I'll think of something and let you know how I did it , come to think of it, this whole build is a first for me so I'll guess continue the "I'll figure as I go" method......well it seems to work
Old 07-30-2011, 06:46 AM
yea, you will figure someting out for the axle im sure. And to me the flares look just fine,I am so excited to think you will be posting a video soon!!!
Old 08-01-2011, 02:29 AM
MrMunster's Avatar
Thanks bud, I've got some ideas floating around for the axle I'm happy with the flares too, well they look like the ones on the big one....
One thing tho, you may want to drop "soon" from posting a vid..... Still a way to go before then me thinks
Old 08-06-2011, 04:51 PM
padre's Avatar
padre padre is offline
SORRY FOR THE AUTOMATIC TRANSLATOR TERRIBLE!
Member Number: 14781
I need to cut 1 cm on one side (less work)
And I think if you could do some final pieces of the axles Axial and others.
A "cap" or terminal attached to the spindle bearing with two screws.
Would be fragile if the axle is sanded to fit a 1-2 mm tube to join the two cut parts?
I guess I was wrong and the translator explained finish the job. Look for a pencil and paper ...
For the rest, all right, but ... those wheels are not LR! (Just kidding)
Greetings.
UN 90 "PA CURRAR" http://www.zonacrawling.com/foros/vi...=4740&start=40
Old 08-08-2011, 08:19 AM
MrMunster's Avatar
Greetings.
I think I understand your thoughts, I have decided to cut 13mm from both sides in order to keep the diff housing on the correct side (yes, more work but looks better and keeps the prop shaft in line with the gearbox output ).
The final pieces of the yota axles should work OK and the axle tube is thick enough to be filed down to fit a collar, this is my plan anyway!!
and you are correct, the wheels are not LR, they are made by Weller for the big one and RC4WD for the little one
Here are some teaser pictures, the front axle has been cut but not put back together as yet
When I have finished the axle chop I will post up how I did it
Old 08-08-2011, 02:29 PM
airwolfie's Avatar
Hiluxian of note
Member Number: 2184
Looking good!! Looks just like your 1:1! I'm just not feeling the bruiser chassis under your landy though, any plans on doing something to it? Or you making a new one from scratch??
Not many "thingy's" left to do though! Wiper blades, mirror, stickers, grille and front bumper. You should be done by friday then!?
Keep it up mate, one of my fav's on here at the moment!
My SeriesII Land Rover
Old 08-08-2011, 02:40 PM
promod's Avatar
promod promod is offline
Canadian Hitech Redneck
Member Number: 734
looks good!!!!
x2 on the bruiser chassis.........
TOYOTA!Killing that Jeep thing ONE rock ONE trail ONE JEEP at a time!
