Old 08-18-2011, 04:00 PM
MrMunster's Avatar
Member Number: 12649
Originally Posted by pardonmyn00b View Post
Nice Land Rover. Where did you get it?
I don't know what else to say, it's just so awesome
Thanks n00b
Originally Posted by Old Busted Hotness View Post
All you got to do is finish it
There had to be a catch seriously tho, that will be an honour
Originally Posted by RCJEEPBUILDER View Post
Nice work on those axles! And the pic of it on the hood of you 1:1 is cool!
Thanks man glad you like the hood shots, seemed better than sat on a tyre or two
Originally Posted by padre View Post
This looks great, may be the solution.
I will wait to see how it worked under the LR.
Collars attached with glue, hold out the work ¿?.
I thought to strengthen the union with a screw or pin miniature, but hold up well, a working less!.
My LR series will not be made ​​for major efforts, only rides a motorized model any more, and the glue may be sufficient.
Greetings.
Oops ... you got those pictures of the chassis of 109?
I think I saw on this topic, but can not find.
Thank you padre, I hope it works under the LR! Yes, collars are glued, the inner collar is longer than the outer too. I can not pull it apart with all my strength so I think glue is sufficient
I am looking for good 109 chassis pictures to send you (soon I hope)
Greetings
  #272
Old 08-18-2011, 04:54 PM
padre's Avatar
padre padre is offline
SORRY FOR THE AUTOMATIC TRANSLATOR TERRIBLE!
Member Number: 14781
I do not want to waste your time, better finish your LR.
I thought I'd saved some level.
I have some things, but would need a profile measures.
But given the 109 "and overall length measures giving no problems and if the chassis is not shaped identical to the 1 / 1 not notice much (not circulate like this)
Uploaded with ImageShack.us
See, most beautiful thing, so will mine.
Rarely seen without the roof here, looks "African" and I really like.
No more annoying you, that I am messing your thread.
Greetings.
UN 90 "PA CURRAR" http://www.zonacrawling.com/foros/vi...=4740&start=40
Old 08-18-2011, 05:10 PM
padre's Avatar
It seems it was only necessary to put the words "magic" in good English in the Google box ...
Old 08-24-2011, 02:27 PM
MrMunster's Avatar
Pare, I don"t think you will find anything more accurate than the coach builders drawings you have....
Made as start on the chassis mods now
Much more to go but within the confines of the Bruiser chassis, it's looking a bit more Land Roverish
Old 08-24-2011, 03:36 PM
padre's Avatar
These drawings are charming, almost ingenuos.Me really like.
We already get used to large 3D drawings and these seem to have 100 years.
Surely build the chassis mixed (plastic, aluminum and fiberglass) as my Defender, which seems tough and I think I can do something like 1 / 1.
regards
From all this, my dear translator does a soup unpalatable.
"Made as start on the chassis mods now "
"Much more to go but within the confines of the Bruiser chassis, it's looking a bit more Land Roverish"
Surely you will understand later, but sise refers to the new pieces look great.
Some paint quickly to get a better idea of ​​the whole.
Greetings.
Old 09-27-2011, 06:07 AM
MrMunster's Avatar
Well I have been on holiday but am back and I have managed to get a bit more work done in the chassis dept
Padre, sorry crazy translator doesn't do his job well! hope this will help....
"made a start on the chassis mods now" = I have started to change the chassis to look more like LR
"Much more to go but within the confines of the Bruiser chassis, it's looking a bit more Land Roverish" = more work to do but as this is a Tamiya Bruiser chassis I am happy it is looking more like a LR chassis.
On with the update...Brazed up the bumpers (after reminding myself how to braze ) and put some paint on
Converted some stock Knight Hauler shocks which I had laying around into something similar to LR shocks. Stock shock on right then one for the rear and one for the front.
Fitted them
Next job is to swap the original three step for an ESC and re-fit the transmission and electrics.
Old 09-27-2011, 09:32 AM
IKke's Avatar
IKke IKke is offline
Oh hai!
Member Number: 5041
Looking forward to seeing this beauty run
IKkeTech Waffle boards, steering Guards, scale wheel hubs, and more!
Check IKkeTech on facebook
Old 09-27-2011, 11:46 AM
airwolfie's Avatar
Hiluxian of note
Member Number: 2184
Looking a LOT better!! The shocks look killer!!
What have you used for the lens mesh? I desperately need some of that for my series II grill, and it looks to be the perfect size!!!
Must....have.........
My SeriesII Land Rover
Old 09-28-2011, 12:59 AM
MrMunster's Avatar
Me too
Cheer mate, does look better now shocks worked out well too
The mesh is....well......mesh was sent a sample from a supplier in Liverpool I had to solder the edges to stop it falling apart as is it a weave but it is a nice scale size (10 holes per inch. 0.56mm wire. Hole size 2mm)
If you must have you better PM me your address and the size you need as I have left overs
Old 09-28-2011, 08:18 AM
MrMunster's Avatar
Couldn't resist.......VIDEO
Well after putting an ESC in it, it would be rude not to Obviously not finished yet and it's only a short video and just a test but still, it's a video!
I know it's not much, no mud (well the front axle has no third member fitted and the cover isn't on the RC box), it still only has two wheel drive and the body's not finished but I hope you like
Old 09-28-2011, 01:58 PM
airwolfie's Avatar
Hiluxian of note
Member Number: 2184
Awesome cheers mate! I will go measure up in a minute and then I'll pm ya!!!
Old 09-28-2011, 10:35 PM
Bulldog's Avatar
Bulldog Bulldog is offline
POWERHOUSE OFFROAD
Member Number: 10058
Nice to see it rolling! I can't wait to see a really nice scale video!
Old 10-01-2011, 02:00 PM
Cullen Cullen is offline
Location: Devonian living in economic exile on the London / Essex border
Member Number: 16244
I really like this build, the scale detail is fantastic. Well done.
I think this build is particularly dangerous to the reader though. Something in the way you've presented the build makes a project like this look possible for meer mortals.
Looks like you have a set of the hwpeterl aluminium wheels - in the pictures on eBay they look great. If that's what they are then are they as good as they look?
Old 10-04-2011, 09:06 AM
MrMunster's Avatar
No problem, still need your address tho
Yeah, was a crowning moment for me....not driven that chassis for 13yrs!! Back then it was a Yota too
Thanks man, Honestly not that difficult well maybe a bit tricky in places
Not hwpeterl wheels, just RC4WD stock steel.
Well having had a little drive and sorted the niggles that were present like the end of the motor shaft rubbing on the grill panel and the front shocks not having enough droop, it's back to detail on the body.....
made some D rings now, just bent a spare control arm into a D shape and brazed it to a base (twice ) and the result...
And for comparison, the lil' one
And the big 'un
Still much to do on the outside but the yard work needs doing before wifey gets home......or......
Old 10-04-2011, 02:32 PM
Woo Hoo!!!! A video! Its looking great man! I would say you should be seeing the light at the end of the tunnel..
