Old 02-25-2012, 07:44 AM
The-Gamer's Avatar
The-Gamer The-Gamer is offline
O tuga
Member Number: 9097
B/S/T Feedback: (19)
Default Hydraulic pump
I have a question regarding hydraulic pumps.
Do they work one way only?
I mean, this one uses a simple motor (dont know about others) and when the motor works the pump starts to "pump" the oil, but what if it the motor turns in the opposite direction? What happens? Does the pump starts pumping oil in the reverse direction? Would that make an hydraulic actuator "open and close"?
Im not sure if I made my question clear...
Old 02-25-2012, 08:08 AM
Tomsloat's Avatar
Tomsloat Tomsloat is offline
Member Number: 13620
From my experience of hydraulic pumps (lifts) they do not work in reverse. And in general hydraulic seals do not like working with negative pressure so you cant really suck a ram closed reliably.
Old 02-25-2012, 08:21 AM
The-Gamer's Avatar
O tuga
Member Number: 9097
Thanks for the reply! Was planning on using this to operate the steering, using a motor connected to a servo board.
Being so, scrapped ideia!
Old 02-25-2012, 08:25 AM
winner's Avatar
winner winner is offline
Member Number: 14500
if its that scale look your going for, i'd look at these:
http://www.junfac.com/shop/index.php...ducts _id=185
Jeeps need more power like a Corvette need mud terrains
Old 02-25-2012, 09:07 AM
Tomsloat's Avatar
It can be done but you would need a double acting ram. ie one with a fitting each end and then a valve to control the pressure each side
Old 02-25-2012, 08:03 PM
The-Gamer's Avatar
O tuga
Member Number: 9097
Not going for the scale look! Just trying something different!
Old 02-27-2012, 08:29 AM
ou812 ou812 is offline
FlatBrokeCustomz
Member Number: 2317
a gear pump can pump fluid either way but.
on real systems the discharge line has to be smaller than the suction to prevent cavitation
a real system has check valves that only let fluid travel one way
Im sure if you set the pump and hoses correctly it wouldnt be an issue.
the only issue I see is smoothness,It takes torque to build up the pressure to be used directly,notice mini pumps spool up before the valves/cylinders are operated,they spool up so the motor has the power and the pump has the pressure to operate smoothly.
If by having all the air bleed out the system and hooked up directly to a cylinder(double action) as soon as the pump motor starts to rotate the cylinder will move,will it be smooth or jerky at low rpm's
Old 02-27-2012, 06:38 PM
Big kid's Avatar
Big kid Big kid is offline
Wasteful spender
Member Number: 16605
There's a bar not far from my house that has some women who will make you retract that statement.
Trying to make the world a better place for everybody one rant at a time.
