Go Back   Scale 4x4 R/C Forums > Scale 4x4 R/C Trux! > 1/8, 1/6 and larger scale Trux!
1/8, 1/6 and larger scale Trux! Discuss your large scale projects here, 1/8, 1/6 and larger scales. Juggy, TXT, Clod, TF, MF and similar based rigs.
Old 02-16-2014, 06:15 PM
350TacoZilla's Avatar
350TacoZilla 350TacoZilla is offline
So you can crawl these little things? LOL
Member Number: 2402
any chance you still have the stock wheels and tires from way back then?
Old 01-01-2017, 01:16 PM
bluedually's Avatar
bluedually bluedually is offline
yes I can tow a house
Member Number: 12594
Haven't worked on this much, hoping to get back to it in the coming months. I like the wheelyking axle width, but still struggling with the tire and wheel combo.
Even at 5 1/2 inches, the mudslingers just feel short.
Old 01-02-2017, 12:44 AM
Member Number: 2402
depends on what you want it to look like lol.
This cxt has 16.00R20 (52" tall 16" wide) Michelin XZL's on the front and 24R21 (54" tall 24" wide) XZL's on the back, I would say you are pretty close to right size tire going by the radius of front wheel wells.
Old 01-02-2017, 11:12 AM
bluedually's Avatar
I've seen that truck before, its pretty sweet. And that is sort of the kind of build I had in mind. The problem is the stock model had 6 inch tall tires, and the 52s on the 1:1 are significantly taller than standard semi truck tires. I think the truck you posted had something like 13 inches of lift.
Old 01-04-2017, 12:45 PM
bluedually's Avatar
One of my chassis ideas, just sheet metal. Was going to use the aluminum channel to beef it up. Might toss this idea and just get some steel tubing and weld something up.
Old 01-04-2017, 05:10 PM
Member Number: 2402
It really depends on what scale your body really is, I have seen those exact bodies listed as 1:6,1:8 and 1:10 with the smaller version listed under both 1:10 and 1:12.
I would guess its between 1:8 and 1:10 since my f350 is supposed to be 1:6 but is really 1:8 and the bed is larger than the cxt beds from what I have seen. The 1:1 cxt trucks use a stock ford 8' long bed and they look pretty small compared to the cab.
16.00r20 16x52" tire scaled down is
1:8 = 2"wide x 6.5"tall / 2.5" rim diameter
1:9 = 1.77" wide x 5.77" tall / 2.2 rim
The Iron Revenge CXT has re-arched stock suspension so I would bet 4" lift max and it could clear those tires up front with 0 lift, the rear fender openings being so small is what kills it for lowering it. Oh and they did lift it after that photo so maybe the new setup is 13" or something but in my opinion it looks kinda goofy now like its on stilts.
Here are two pics of my f350 bed which is supposed to be a 6.5' short bed ford compared to a 1:1 8' bed
Old 01-04-2017, 05:39 PM
bluedually's Avatar
It's definitely the bigger body. Surfing rc4wd's site they have a 7.55 x 3.5 inch Mudslinger in the 40 series. I am kinda leaning in that direction. I did just for the hell of it send them an e-mail asking about some sizes in between the tallest 2.2 tire and the 40 series. Along with asking about how much some custom height Mil-Spec ZXLs might cost me
This is the full body sitting on my HPI Crawler King, wheel base, Wheely King. That's when the 5.5s look a bit to short lol.
Old 01-04-2017, 11:40 PM
Member Number: 2402
oh I know yours is the bigger version, I'm just saying I'm not sure what it exactly scales out to but I think its around the 1/8th or 1/9th not 1/6th like nb sold it. I would bet if you had a tire in the 6-6.75 height it would fill the fender completely, heck if you look at my one pic you can see I have 3" of clearance just with the bed sitting on table so I should be able to fit a 6" tire completely stuffed in fender.
I need to find someone local with one of those trucks to compare the beds lol. How does the 5.5 tire fit in rear fenders compared to fronts?
I have a set of large BFG AT tires I'll have to measure sometime, I think they are 6.5 tall x 2.5 wide and fit a 3.0 or 3.2 rim cant remember.
Old 01-05-2017, 07:57 AM
bluedually's Avatar
I'll get some measurements later today. Boss just texted us to tell us we aren't working because of the snow we got here in Idaho.
Old 01-09-2017, 02:10 PM
Member Number: 2402
Just a heads up prolines 2.2 bfg's are 5.65" and their swamper 2.2 XL is 5.8 so that might work out for you .
Old 01-14-2017, 06:52 PM
Member Number: 2402
Hey I did find those tires they are 6 and 1/8th tall and 2.5 wide and fit traxxas 3.2 wheels and look just like bfg at, let me know if your interested.
Old 01-14-2017, 10:38 PM
bluedually's Avatar
Yeah I would be interested in them.
Old 02-16-2017, 08:27 PM
bluedually's Avatar
Forgot I had saved some stuff on Amazon for this build and the wife ordered and got them shipped out today with part of our tax return.
It will be a HPI Wheelyking/ Traxxas Emaxx hybrid. Dual motor emaxx trans into the HPI trans and out to HPI axles.
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
Copyright 2004 - 2017, Scale 4x4 R/C
