Old 05-06-2015, 12:47 PM
UK_Andy's Avatar
UK_Andy UK_Andy is offline
www.mishacalvin.com
Member Number: 4544
In my mind the courses are rough with some steep sections but the gates are class 3 width and spread out over a longer distance, so there can be a bit of speed involved. And I think the course should be timed. I dont think a winch will ever be needed.
I know these are 2wd but its the kinda idea on courses and what not...
www.mishacalvin.com
Old 05-06-2015, 12:51 PM
Squidger's Avatar
Squidger Squidger is offline
Still got a lot of learning to do
Member Number: 2259
I might just use the Tamiya wild dagger chassis that I have, got the dual esc with it aswell so I will just use two stock 27t tamiya motors and take one out if you guys deem it as an advanatage, and just go rwd or fwd =), and use the tires seen on the XV01 I linked in the earlier post.
Wild Dagger vs TB01
Current collection : D90 custom chassis, D90 Wild Dagger Chassis, Hilux CC01, Bronco 3SPD highlift, TL01B Wild Dagger Monster truck and many tamiya touring cars
Old 05-06-2015, 12:53 PM
UK_Andy's Avatar
www.mishacalvin.com
Member Number: 4544
Wild Dagger vs TB01
I think a rally tyre is gonna be too small but if we go with a 100mm max tyre then its up to you.
Your TB01 looks just the kinda thing iv been trying to get across
www.mishacalvin.com
Old 05-06-2015, 12:56 PM
Dready's Avatar
Dready Dready is offline
Member Number: 2380
Think it needs to be 4wd, 2wd isnt a good idea.
100mm tyre size max sounds fine
Old 05-06-2015, 01:08 PM
4WheelRC's Avatar
4WheelRC 4WheelRC is offline
Scale truck obsessive.
Member Number: 21252
Someone has to bring along one of these, just for the old-school epicness: No need to lock the diff, as it never had one (yeah I know 2WD would suck, but hey)!
http://www.modelsport.co.uk/index.ph... RihoCYrnw_wcB
Edit: Oh noes, now I've started browsing vintage Tamiya sites. Sheesh I must be getting old
Old 05-06-2015, 02:07 PM
UK_Andy's Avatar
www.mishacalvin.com
Member Number: 4544
I agree but.....if you want to use 2wd then this class would allow it.
I'm gonna try and write up some rules tonight!
www.mishacalvin.com
Old 05-06-2015, 02:42 PM
UK_Andy's Avatar
www.mishacalvin.com
Member Number: 4544
Default class 0 rules
Max tyre size 101mm
Any size wheel 2.2, 1.9, 1.5, 1.7
Max width 235mm
Any chassis
4wd or 2wd, 1 diff only locked, front or rear.
No motor limit, brushed or brushless.
Must be of scale appearance, all electrics hidden
10 gates, min width 10" max width 12"
10 second penalty for each gate hit
no penalty for reverse
There will be certain sections where you will have to follow markers but they are not counted gates
Each course will be run in each direction
1 motor only
No MOA.
2s lipo or 7.2v nimh/nicad.
www.mishacalvin.com
Old 05-06-2015, 03:16 PM
UK_Andy's Avatar
www.mishacalvin.com
Member Number: 4544
My tt01 holiday buggy is 210mm wide. 255mm wheelbase. 96mm tyres. Max ground clearence is 45mm.
www.mishacalvin.com
Old 05-06-2015, 06:21 PM
Darkcrawler6x6's Avatar
Darkcrawler6x6 Darkcrawler6x6 is offline
Call me Snowman!
Member Number: 16526
Andy would you add brushed motor only? Or we going to include brushless setup as well?
Old 05-07-2015, 12:36 AM
4WheelRC's Avatar
My vote would be to not restrict either motors or batteries. Let folks use what they have lying around?
For example, I have an old 13.5T brushless motor kicking around that I would use as it is less maintenance than brushed. With the tire restrictions for this new 'Class' I doubt that racking up with a 6S rig and a high kV motor would gain much advantage?
Old 05-07-2015, 12:55 AM
UK_Andy's Avatar
www.mishacalvin.com
Member Number: 4544
No motor limit (I'll add that into the draft rules) but I think the battery spec should stay.
www.mishacalvin.com
Old 05-09-2015, 04:10 PM
Turbofurball's Avatar
Turbofurball Turbofurball is offline
Trundler on tour
Member Number: 23348
I guess with some of the terrain being rough having a monster brushless setup wouldn't be an advantage at all ... ideally, you want courses that mix it up enough that a thorough all-rounder is the sweet spot!
I might have started planning a suitable truck ...
Old 05-10-2015, 06:41 AM
4WheelRC's Avatar
Agreed, my e-Revo (on 4S, let alone 6S) cannot trail for toffee Avec le gear differential, le trail c'est tres difficile!
Old 05-10-2015, 11:28 AM
sgl's Avatar
sgl sgl is offline
Member Number: 19298
It's an interesting idea. Although I do like the idea of 2wd as a class of it's own.but that's probably because of the old school almost single wheel drive cars shown in the later part of the thread. The idea of the course designed around those would certainly sort out the cars.
SGL
Old 05-14-2015, 12:10 PM
UK_Andy's Avatar
www.mishacalvin.com
Member Number: 4544
http://www.thercracer.com/2015/04/58...mny-first.html
Hmmm...Ideal for this new class idea
www.mishacalvin.com
