Go Back   Scale 4x4 R/C Forums > Monsters, Scale 4X2, & Non scale R/C > Rock Crawlers
Rock Crawlers For those Rock crawling, stone sliding, body scratching, articulation crackheads; this place is for you!
Old 11-18-2016, 06:53 PM
_sOnGoKu_'s Avatar
_sOnGoKu_ _sOnGoKu_ is offline
Member Number: 24796
Default HB 1801 CONQUEROR Rock Crawler RC 4x4 - 1/18 - UnBoxing + Review + Tips
Hello friends, I have prepared this thread to talk a little about my first Crawler.
After ordering with free shipping, and wait patiently around 15 days, finally arrived!
i,m glad to present you to the "little one" of the family. From the manufacturer HB, I have this model P1801 some
people call it "Conqueror", there are several manufacturers wich has the same or very similar models. JJRC with
its model JJRC Q21 RC Car Rock Crawler ,
*WLtoys with your model WLtoys 18428 - B , these I have not tried, but since they
are similars if not just the same car with diferent controller.. to my understanding they're just as good as this.
The small crawler, has a scale of 1/18 (1:18) and has a total OFF-Road perosonality. With its 4-wheel drive with an
engine by axle, this P1801 is capable of climbing by unimaginable places.
It is made in resistant ABS and with a racing crowler look, full of details.
The car is RTR, also come with the batteries for the transmitter (a nice detail), you can start playing with it just out
of the box!
Even the battery is charged! .. the truth, this little one, has not ceased to amaze me from the first moment that I had
it in the hands.
UNBOXING VIDEO
Thanks to its independent differentials, has a pair of traction much higher than other RC cars, this takes away speed
but it gives you an extra power, perfect when facing the higher obstacles and climbing above them with ease.
It has a servomotor for the direction that is mode "all or nothing", like the gas, being perhaps this its greater defect
i found on it .. But we must remember that it is a car that costs 20, we can not ask for much more for that price.
It is equipped with independent suspension on the chassis, giving a great travel range of the same and working together with
the car's engines to get out of any situation where it can be found.
The car has such nice details as, Seats, steering wheel, spare wheel etc.
The battery that works is 4.8V and gives you between 15 and 20 minutes of fun, taking to fully charge about 2 hours.
I bought also 2 extra batteries for it (for 2 each) so they are cheap.
With the three batteries, I can go for one hour doing Crawling without stopping .. a joy ..
The command, although simple is nice, I repeat that its controls are a (all or nothing) for both the movement and
the direction. It works with 3 AA batteries (included), the consumption of the transmitter is minimum. I have calculated
that it has a range of about 50 meters . Distance more than enough by the size of this small P1801 Crawler. It works at
2.4GHz, 2Ch so it's perfect for running more cars at the same time without interference.
In short, I see it a very versatile car, both for a small child, for its easy handling, low speed size and weight, and also
*I see it a great car, for those who would like to tune up a crawler a little more serious but do not want to spend the 100
they usually cost.
It is clear, this truck will always be a "toy" but if you are a little handy, it will not cost much to modify and improve it.
I'm thinking of updating it with an ESC and a digital servo of the directon it brings, for what it is, it's not going bad either, but I can not control The throthle is what most bother me when it comes to going to the field. Even so, the fun is assured.
Pros:
its price! About 20
Shock Resistance
Several manufacturers make similar models (easily interchangeable parts)
Cons:
Address and gas all or nothing
Links of interest
You can see more technical features here:
Direct link to HB P1801 http://www.gearbest.com/rc-/pp..
Direct link to extra battery http://www.gearbest.com/rc-/pp..
Use these codes to have more decuentro: RC15OFF , RC18OFF , RCOF
Friends, this car goes all over the place! And proof of it, I leave these little videos that I mounted having a good time with him.
HB P1801 Rock Through Crawler First Run - 1 # Adventure 1/18 4WD @ The Road
HB 1801 - CONQUEROR 4x4 Rock Crawler # 2 Adventure 1/18 @ Cas berris Torrent
All the other videos here:
SongoLand YouTube
I'll hang around here the things I'm doing to the little one.
a greeting!
Old 01-28-2017, 05:34 AM
_sOnGoKu_'s Avatar
i made some iprovements in this little crawler HB 1801
New ESC and servo direction (proportional) and new Reciver.. works just awesome.
a gretting
