Old 07-10-2007, 06:47 PM
TheROOSTER's Avatar
TheROOSTER TheROOSTER is offline
Member Number: 2050
Default My answer to STIFF suspension
To get more flex out of my HL I added Traxxas ball ends to each end of each leaf allowing the springs to rock side to side. This does require cutting the leafs, but it is worth it. I almost doubled the flex. I have tried the chino spring mod but this works better for me with less slop.
First, for measurement purposes attach the longest leaf to the main leaf. Then take metal cutters and cut the main spring the same length.
Name:  Spring Mod 001.jpg
Second, make a 90 degree bend about 8mm back at each end.
Name:  Spring Mod 002.jpg
Resulting in this.
Name:  Spring Mod 003.jpg
Next drill about a 1/8" hole in each end and round off the square ends.
Name:  Spring Mod 004.jpg
I wanted to use the stock HL screws that hold the springs on so I drilled the Traxxas balls out with a 3/16" drill. Screws that fit through the balls could be used but some type of shim or spacer would be needed in the springs mounts on the truck.
Name:  Spring Mod 005.jpg
The finished springs.
Name:  Spring Mod 006.jpg
Now remove the long second spring that was used for measuring and put whatever spring is desired. Mount them on the chassis. This may require a washer to shim between the ball end and spring mount or the mounts can be bent in to take out the side-side play.
Name:  Spring Mod 007.jpg
Name:  Spring Mod 008.jpg
Complete.
Name:  Spring Mod 009.jpg
Old 07-10-2007, 07:06 PM
Thorsteenster's Avatar
The 4rd prize winner!
Member Number: 990
nice idea, now thats different!
www.varcoffroaders.com
Old 07-10-2007, 07:16 PM
Suprachrgd82's Avatar
is such a jerk!!
Member Number: 1781
That's really enginuitive! How in the world did you figure that out?
Old 07-10-2007, 07:48 PM
SteveK SteveK is offline
Member Number: 1360
Niiice
Real trucks have some sort of bushing in the leaf eyes, makes for better articulation. I might have to try this.
Old 07-10-2007, 07:50 PM
TheROOSTER's Avatar
Member Number: 2050
Thanks. I was just so tired of the crappy flex. I finally realized that it was not caused by the firm springs, but the inability for the springs to rotate side-side.
Old 07-10-2007, 07:53 PM
TheROOSTER's Avatar
Member Number: 2050
Originally Posted by SteveK View Post
Niiice
Exactly. Thinking about that is what led me to this.
Old 07-10-2007, 08:02 PM
Member Number: 1360
You can also fine-tune the springs with this too: Spacing the rod-ends out further from the center will soften up the spring.
Old 07-10-2007, 08:07 PM
fender fender is offline
Member Number: 1230
Nice mod, that should also make it easier to make up springs from scratch.
Old 07-10-2007, 11:41 PM
obijuan obijuan is offline
100% texan
Member Number: 1340
gooood idear!
american by birth. Texan by the hand of God. amen
Old 07-11-2007, 09:31 PM
twisted twisted is offline
Member Number: 131
is that max flex ?
if you like horror check out my art site at :
http://mysite.verizon.net/twistedmentality/
Old 07-11-2007, 09:56 PM
Electrohacker's Avatar
Electrohacker Electrohacker is offline
Member Number: 151
I wonder how this compares to a chinco mod which also addresses the twisting motion of a leaf
Old 07-11-2007, 11:49 PM
Jugg2Driver's Avatar
Member Number: 3
Excellent modification!
Old 07-13-2007, 07:01 AM
TheROOSTER's Avatar
Member Number: 2050
Originally Posted by twisted View Post
is that max flex ?
No. It has about another half inch.
Thanks for the compliments guys.
Old 07-13-2007, 07:18 AM
Member Number: 990
i wonder if anyone has tried it in 1:1, although probably not much need for it since the load is way more than on comparetivily on an rc. but there are composite leafs, i dont see why they couldnt put a ball end in each end.
Old 07-13-2007, 08:46 AM
Rikpal's Avatar
Rikpal Rikpal is offline
Administrator - The forest dwelling drunken hobo. I'm ugly and stink
Member Number: 6
Interesting mod
Rik - The Italian Guy
www.scalersandcrawlers.it - "THE" Italian Scalers and Crawlers Board - http://rikpal.golem100.com - rik.paltrinieri@gmail.com
If you have an apple and I have an apple and we exchange apples,then you and I will still each have one apple.
But if you have an idea and I have an idea and we exchange these ideas, then each of us will have two ideas.
G.B.Shaw
Wannabe member of MtTABRA (More than Three Axles Big Rig Association)
