Go Back   Scale 4x4 R/C Forums > Scale 4x4 R/C Trux! > Tips, Tricks, FAQs > Styrene Extreme
Styrene Extreme Tips and tricks and working with sheet styrene for those ultimate custom builds!
Old 03-09-2008, 03:51 PM
Amji's Avatar
Amji Amji is offline
I bilt beter tan I rite
Member Number: 2070
Default simple thinking in styrene
Hi
after a lot of nice comments and a lot of questions about how I build that
101"body about my thechnices ......
I thought they all can do that
all things are build up from simple forms like tube ,rods ,blocks and balls
keep that in mind and you will build the most beautifull things
( i'm going to ad "I build better then I write "to my name )sorry for my bad english
the first thing I wanna show you is making a hinge
First take a strip and a pice of rod and cut two squares and same length rod
cut some discs from the rod like this
or
then lay the rod in the gap of the door and lay all the pices in there place
add a little glue and the result is a nice hinge (non opening)
I hope to contribute a small thing for better builds
AmJi
Old 03-09-2008, 03:53 PM
weeb_beano's Avatar
weeb_beano weeb_beano is offline
Forum Member
Member Number: 287
Thanks for sharing! This is very clean and elegant...
Not supporting RC4WD until they get their act together.
http://www.beanos.com/%7Etsoutij/sigs/r_c.jpg
Put this link in your sig: http://www.scale4x4rc.org/forums/sho...972#post247972
Old 03-09-2008, 04:02 PM
DrKucho's Avatar
DrKucho DrKucho is offline
Member number 404 , what's that? Member not found?
Member Number: 404
yeah yeah ! we need more usefull tips like this !!
Old 03-09-2008, 04:36 PM
2011 Post Whoring Champion
I'm with Amji, I thought everyone knew that....
Old 03-09-2008, 05:10 PM
Thorsteenster's Avatar
The 4rd prize winner!
Member Number: 990
B/S/T Feedback: (13)
Itried it but as soon as the torch hit it, it melted! So I used brass instead.....
It is nice to see a thread dedicated to easy but maybe not known tricks for styrene.
www.varcoffroaders.com
Old 03-09-2008, 10:31 PM
cflight's Avatar
cflight cflight is offline
Member Number: 2887
Excellent!
The lines are open, now taking requests?
How about the tools on the front of the 101?
That shovel is burned in my brain.
Old 03-10-2008, 04:16 AM
zabbe's Avatar
zabbe zabbe is offline
V.A.G. Dude
Member Number: 2487
Nice!
Keep it coming
VW Iltis|VW Taro|Audi Quattro
Old 03-12-2008, 12:49 PM
Amji's Avatar
Member Number: 2070
Hi
This time a request (cflight)
Today I wanna show you the making off a shovel
In this picture you see all necessarily items
Pice of styrene ,some rod, some tube, a lighter ,a knife and a file
First heat up the underside off the 2mm sheet off styrene and when its soft press softly the end of your knife(a screwdriver will do as well) into the soft styrene
When that is good take the pice between your fingertips and when it’s in the middle you can draw around your finger the shape off the shovel, then cut it out
Then file the edges round in the shape you need .
Afther that take the rod ,heat it a bit and bend a S shape in it
Then make the part of the handle that will overlay the blade half round ,cut a ring off the tube and cut the back handle
Then glue the parts togetter
And cut away some material in the white arias so the blade looks thin
Happy building
AmJi
Old 03-12-2008, 03:17 PM
DrKucho's Avatar
Member Number: 404
Old 03-15-2008, 04:43 PM
cflight's Avatar
Member Number: 2887
That's how he did it!!!
I thought it was carved to shape? Great tip!
Old 03-16-2008, 10:50 AM
happyelk's Avatar
happyelk happyelk is offline
slooow builder with way too many ideas
Member Number: 816
Nice idea with the shovel, Amji!
You don´t need roads – when you can make your own!
Old 03-16-2008, 04:03 PM
gonna put that shovel tip to use on my mog project. thats great!
Old 03-16-2008, 11:11 PM
jaymillz517's Avatar
Those who stayed, sucked!
Member Number: 2190
nice shovel.. i couldnt figure it out..
25th out of 9,164 ain't to bad!
Old 03-17-2008, 12:57 PM
Bin 'jammin''s Avatar
Bin 'jammin' Bin 'jammin' is offline
Modified mind
Location: Somewhere in sunny Southampton, supposedly the third most dangerous city to live in the UK
Member Number: 1978
Excellent, thanks for sharing.
Can you show us how you made the fire extinguisher on the front too?
So i rang up my local builders and said "I want a skip outside my house" and he said "Well i'm not stopping you"....
Old 03-18-2008, 05:49 AM
Dutch4x4 Dutch4x4 is offline
Shut up and Drive
Member Number: 3255
hehehe
i got the spade already at home amji gave it to me for my roofrack
